Please Help. My board is not working.
Riu
Postby Riu » Wed Feb 15, 2017 7:57 pm
Hello.
I have a ESP8266EX_Demo board.
I downloaded binaries in ESP8266_NONOS_SDK_V2.0.0 to the board to use AT commands.
And I can see some message when the connection is occurred, but I can’t see any response from the board when I sent AT command using PC.
Please see below steps(images) and let me know what is wrong or missing.
Demo board image
Downloading binaries
PC terminal App. setting.
I can see some of message when connection is occured.
Sending AT command. Write "AT" and press 'Enter' key. I can't see any response from demo board.
ESP_puff
Re: Please Help. My board is not working.
Postby ESP_puff » Thu Feb 16, 2017 9:53 am
Hello Riu,
AT command should go along with a newline
if you send "AT+GMR", it will not give you any response
But if you send "AT+GMR" and add a new line after that, it will work
Espressif
Puff
FAE
Riu
Postby Riu » Thu Feb 16, 2017 1:33 pm
Hello Puff
Thanks for your replay.
I think ‘add a new line’ same as pressing ‘Enter’ key in the application.
The last image shown the final situation when write “AT” + press ‘Enter’ in PC.
The cursor moves first column after pressing 'Enter' key, same as in case of "AT+GMR".
If you know other method to add a new line with PC or the other PC application to send AT command, please let me know. (My OS is Windows7)
Riu
RiliyVax
Please Help My board is not working
Postby RiliyVax » Mon May 01, 2017 6:18 pm
Can I please post the launcher output? What is the launcher output and where do I find it. Wdym that I am not running forge. I am not running forge because my minecraft keeps crashing when I try to play with forge.В
