Hardware flow control UART
Jan Kijonka
Postby Jan Kijonka » Mon Sep 04, 2017 8:42 pm
Is it possible to communicate between a host MCU and ESP12-E via UART using hardware flow control and AT+Commands ?
If so, do you have some connection diagram for GPIO RTS/CTS connection and software setup ?
Thank you,
Jan
Re: Hardware flow control UART
Postby pratik » Tue Sep 05, 2017 4:37 pm
The UART baud rate configuration AT command can be used to enable flow control. Please check the AT command documentation for your version of the firmware.
As for the GPIOs, when flow control is enabled:
GPIO12 = U0DTR
GPIO13 = U0CTS
GPIO14 = U0DSR
GPIO15 = U0RTS
Jan Kijonka
Postby Jan Kijonka » Wed Sep 06, 2017 4:03 pm
Dear pratic,
I looked for the flow control in AT Commands sheet. I have only found "AT+UART" command, which allow flow control:
<flow control>: flow control
‣ 0: flow control is not enabled
‣ 1: enable RTS
‣ 2: enable CTS
‣ 3: enable both RTS and CTS
But what about DTR (Data Terminal Ready) - GPIO12 and DSR (Data Set Ready) GPIO14 ? Are these sognals also included when I enable only RTS and CTS ?
Postby pratik » Wed Sep 06, 2017 10:04 pm
You can only use RTS and CTS, but that is typically enough for most applications where you want to control data flow in case your host is slow to process data.
I'd suggest allowing the UART flow from ESP->host always when the host can process data.
