ESP8266 Sends UDP data
Postby ESP_Faye » Tue May 12, 2015 5:55 pm
If using espconn in ESP8266_RTOS_SDK, please call espconn_init in user_init as initialization.
     * Copyright 2013-2014 Espressif Systems
#include "ets_sys.h"
#include "os_type.h"
#include "osapi.h"
#include "mem.h"
#include "user_interface.h"
#include "espconn.h"
#include "user_json.h"
#include "user_devicefind.h"
LOCAL os_timer_t test_timer;
LOCAL struct espconn user_udp_espconn;
const char *ESP8266_MSG = "I'm ESP8266 ";
LOCAL struct espconn ptrespconn;
  * FunctionName : user_udp_recv_cb
  * Description  : Processing the received udp packet
  *                pusrdata -- The received data (or NULL when the connection has been closed!)
  *                length -- The length of received data
  * Returns      : none
 LOCAL void ICACHE_FLASH_ATTR
 user_udp_recv_cb(void *arg, char *pusrdata, unsigned short length)
     os_printf("recv udp data: %s\n", pusrdata);
      * FunctionName : user_udp_send
      * Description  : udp send data
      * Parameters  : none
      * Returns      : none
 user_udp_send(void)
     char DeviceBuffer[40] = {0};
     char hwaddr[6];
     struct ip_info ipconfig;
     const char udp_remote_ip[4] = { 255, 255, 255, 255};
     os_memcpy(user_udp_espconn.proto.udp->remote_ip, udp_remote_ip, 4); // ESP8266 udp remote IP need to be set everytime we call espconn_sent
     user_udp_espconn.proto.udp->remote_port = 1112;  // ESP8266 udp remote port need to be set everytime we call espconn_sent
     wifi_get_macaddr(STATION_IF, hwaddr);
     os_sprintf(DeviceBuffer, "%s" MACSTR "!" , ESP8266_MSG, MAC2STR(hwaddr));
     espconn_sent(&user_udp_espconn, DeviceBuffer, os_strlen(DeviceBuffer));
      * FunctionName : user_udp_sent_cb
      * Description  : udp sent successfully
      * Returns      : none
  user_udp_sent_cb(void *arg)
      os_printf("user_udp_send successfully !!!\n");
      //disarm timer first
       os_timer_disarm(&test_timer);
      //re-arm timer to check ip
      os_timer_setfn(&test_timer, (os_timer_func_t *)user_udp_send, NULL); // only send next packet after prev packet sent successfully
      os_timer_arm(&test_timer, 1000, 0);
 * FunctionName : user_check_ip
 * Parameters   : none
 * Returns      : none
user_check_ip(void)
    if (wifi_station_get_connect_status() == STATION_GOT_IP && ipconfig.ip.addr != 0)
      os_printf("got ip !!! \r\n");
      wifi_set_broadcast_if(STATIONAP_MODE); // send UDP broadcast from both station and soft-AP interface
      user_udp_espconn.type = ESPCONN_UDP;
      user_udp_espconn.proto.udp = (esp_udp *)os_zalloc(sizeof(esp_udp));
      user_udp_espconn.proto.udp->local_port = espconn_port();  // set a available  port
      const char udp_remote_ip[4] = {255, 255, 255, 255};
      espconn_regist_recvcb(&user_udp_espconn, user_udp_recv_cb); // register a udp packet receiving callback
      espconn_regist_sentcb(&user_udp_espconn, user_udp_sent_cb); // register a udp packet sent callback
      espconn_create(&user_udp_espconn);   // create udp
      user_udp_send();   // send udp data
   else
                wifi_station_get_connect_status() == STATION_CONNECT_FAIL))
         os_printf("connect fail !!! \r\n");
      else
            os_timer_setfn(&test_timer, (os_timer_func_t *)user_check_ip, NULL);
 * Parameters   : none
 * Returns      : none
user_set_station_config(void)
   // Wifi configuration
   char ssid[32] = SSID;
   char password[64] = PASSWORD;
   //need not mac address
   stationConf.bssid_set = 0;
   //Set ap settings
   //set a timer to check whether got ip from router succeed or not.
 * FunctionName : user_init
 * Parameters   : none
 * Returns      : none
void user_init(void)
   //Set softAP + station mode
   //ESP8266 connect to router
   user_set_station_config();
If you want to send back a response when received one,
     struct espconn *pesp_conn = arg;
       remot_info *premot = NULL;
       sint8 value = ESPCONN_OK;
       if (espconn_get_connection_info(pesp_conn,&premot,0) == ESPCONN_OK){
             pesp_conn->proto.udp->remote_port = premot->remote_port;
             pesp_conn->proto.udp->remote_ip[0] = premot->remote_ip[0];
             pesp_conn->proto.udp->remote_ip[1] = premot->remote_ip[1];
             pesp_conn->proto.udp->remote_ip[2] = premot->remote_ip[2];
             pesp_conn->proto.udp->remote_ip[3] = premot->remote_ip[3];
             espconn_sent(pesp_conn, pusrdata, os_strlen(pusrdata));
usd18290
Re: ESP8266 Sends UDP data
Postby usd18290 » Mon May 23, 2016 8:35 pm
I think the response code got issue. The proto should be udp instead of tcp, right ?
Postby ESP_Faye » Tue May 24, 2016 10:03 am
Thanks! We revised it.
semlanik
Postby semlanik » Thu Jan 11, 2018 8:12 pm
Hi all,
I'm trying the similar thing in my network but using station instead of AP. And it doesn't work. I also tried calculate broadcast address accordding IP and mask it doesn't work as well. But send to particular IP works fine.
Any ideas of this behaivor?
I'm using non-os SDK 2.1.x.
Alexey.
Postby Her Majesty » Mon Jan 15, 2018 3:14 pm
Try station_only mode when calling wifi_set_opmode. And also call wifi_set_broadcast_if (STATION_MODE); to enable broadcast in the station mode.
