ESP WIFI MESH DEMO
ESP_Bill
ESP WIFI MESH DEMO
Postby ESP_Bill » Thu Jan 21, 2016 5:29 pm
Wi-Fi Mesh 特点:
WIFI mesh组网无需对原有Router环境进行任何修改,即可实现大量的IOT mesh 节点接入互联网,解决大量WIFI 设备不能同时接入Router的问题。
关于ESP Wi-Fi Mesh:
附录链接为 ESP8266 实现 Wi-Fi Mesh 功能的sample code,内含详细说明,可帮助开发者快速理解并掌握ESP WiFi Mesh。
(1). 目前 ESP mesh 已经实现稳定支持78个wifi IOT 智能灯同时接入普通家庭路由,并且这个接入的数量还可以更多...
(2). ESP 提供易于编程的API,并提供详细的示例代码,帮助产品快速实现WiFi mesh组网
Wi-Fi Mesh Features:
Wi-Fi Mesh network supports a large number of IoT mesh nodes to connect internet without any improvement of home router, so WiFi mesh is feasible solution to fix the capacity of home router.
About ESP Wi-Fi Mesh:
We have released the mesh demo on github, you can clone the source code from attached link. The document is attached in demo, you can find the APIs in document. The demo will help you to establish mesh network using ESP8266.
(1) mesh_demo.c provides framework to develop device application based on mesh.
(2) demo_server.py provides the demo to construct mesh header for mesh packet on cloud server.
(3) By now, ESP mesh has supported 78 Wi-Fi IoT smart lights to connect internet simultaneously and stably using one common home router, and the capacity of mesh nodes could be more.
Link: https://github.com/espressif/ESP8266_MESH_DEMO
robertiko
Re: ESP WIFI MESH DEMO
Postby robertiko » Wed Feb 24, 2016 11:48 am
hi
i can´t find the file mesh_demo to set up according to demo_server.py
can you teach me?
Postby ESP_Faye » Tue Mar 01, 2016 10:36 am
Sorry, mesh_demo is not file, it's local server.
You can use demo_server.py to setup the local server for mesh node.
We have improved the "readme" about mesh demo and thanks very much for your feedback.
venkatesan9751
Postby venkatesan9751 » Thu Mar 10, 2016 8:30 pm
i am not able to build the file. it's giving the error.
is it possible to build the file using eclipse ide. if yes. please provide steps. i have tried with default Makefile but giving error.
i have tried in Linux but some of the Packages is not installing and while building the toolchain, permission denied error is coming(./ct-ng build).
if you have gen_misc.bat file for windows, please share here.
Thank you.
Postby ESP_Faye » Wed Mar 16, 2016 2:17 pm
What is the error information of you compiling?
Would you like to have a try with our compile environment http://bbs.espressif.com/viewtopic.php?f=50&t=86?
