【Feedback】ShowCritical:0 ??
mash
Postby mash » Tue May 31, 2016 6:32 pm
I'm seeing this in the logs just before resetting, while doing some heavy crypt calculations.
ShowCritical:0
ets Jan 8 2013,rst cause:4, boot mode:(3,6)
wdt reset
load 0x40100000, len 1856, room 16
tail 0
chksum 0x63
load 0x3ffe8000, len 776, room 8
tail 0
chksum 0x02
load 0x3ffe8310, len 552, room 8
tail 0
chksum 0x79
csum 0x79
2nd boot version : 1.5
SPI Speed : 40MHz
SPI Mode : QIO
SPI Flash Size & Map: 32Mbit(1024KB+1024KB)
jump to run user1 @ 1000
What does this mean? And how can we avoid this?
I'm using the latest 1.4.0 RTOS SDK.
ESP_Rubin
【Feedback】Re: ShowCritical:0 ??
Postby ESP_Rubin » Thu Jun 30, 2016 3:37 pm
sorry, i never reproduce this issue on my board, maybe you can mark the print in ./third_party/freertos/port.c:314: ets_printf("ShowCritical:%d\n",uxCriticalNesting);
mengzawj
Re: 【Feedback】Re: ShowCritical:0 ??
Postby mengzawj » Wed May 17, 2017 11:06 pm
ESP_Rubin wrote:sorry, i never reproduce this issue on my board, maybe you can mark the print in ./third_party/freertos/port.c:314: ets_printf("ShowCritical:%d\n",uxCriticalNesting);
I have run into the same problem,any suggestions?
[2017-05-17 22:55:32.784 R]ShowCritical:0
[2017-05-17 22:55:33.190 R]
load 0x40100000, len 31268, room 16
tail 4
chksum 0xe1
load 0x3ffe8000, len 2240, room 4
tail 12
chksum 0x70
ho 0 tail 12 room 4
load 0x3ffe88c0, len 1264, room 12
This problem sometimes arise,and no other exceptions!
Star
Re: 【Feedback】ShowCritical:0 ??
Postby Star » Thu Aug 24, 2017 4:25 pm
in freerots/port.c found below
/* Each task maintains its own interrupt status in the critical nesting
variable. */
static unsigned portBASE_TYPE uxCriticalNesting = 0;
i guess appear this “ShowCritical:0” because Called a function that should not be called in task
My condition is to open the software timer in the task the timer calls the nopoll_conn_send_text () function so "ShowCritical 0" appears but I call the nopoll_conn_send_text () function in the queue's callback function Then my program is normal and normal operation
ritesh
Postby ritesh » Sun Sep 10, 2017 1:27 am
Did you find anything for your issues?
We are getting ShowCritical:1 issue and then Watchdog Reset after that in my application but we have used xTaskEnterCritical and xTaskExitCritical while writing data into SPI Flash memory.
Ritesh Prajapati
Users browsing this forum: Bing [Bot], Google [Bot], Yahoo [Bot] and 3 guests
