Question concerning the topology-request
Lukas F.
Postby Lukas F. » Tue May 02, 2017 9:05 pm
Good morning from Germany,
I'm currently working on an own implementation of an ESP8266-based mesh-network. I really like your demo-version and most of the implementation-details are understandable, but there is one point I can't get to figure out concerning the topology-request, or, to be more precise in the function mesh_none_proto_parser in mesh_none.c and I was hoping, that you would be able to help me. :-)
The question is the following:
Does only the root-device react to a topology-request or all nodes reached by the broadcast from mesh_topo_test? Just looking at mesh_none_proto_parser, it would seem, that only the root device answers (with M_O_TOPO_RESP as option and all currently registered devices MAC-addresses as option-value). But from mesh_parser.c I would think, that all nodes reached by the broadcast should execute mesh_none_proto_parser and therewith set the MAC-address of the sending node as root as well as the broadcast-address as a sub-device.
I really hope that you can help me. :-)
If you are interested, I can upload my own mesh-implementation to Git as a further example after I finished it.
With best regards,
Lukas
