High priority interrupts
mculibrk
Postby mculibrk » Mon Apr 27, 2015 2:39 am
I noticed the ESP core should have support for high priority interrupts (from the .h files describing the CPU found in the RTOS SDK).
I would like to know how can the high priority interrupts be configured?
I would like to make the SPI interrupt a high priority one, so it could have it's own interrupt vector (not using the current "shared handler") to avoid the rather high >1uS latency of the ETS_INT_ATTACH() functions.
Any hint/comment would be greatly appreciated.
MCulibrk
dkaufmann
Re: High priority interrupts
Postby dkaufmann » Tue Nov 22, 2016 7:47 pm
i am also looking for a solution to have a faster GPIO interrupt. Entering and reading and input with the standard API functions takes >2.5us which is way too slow (at 160MHz this is around 400 cycles!!). Could you find a solution?
A high priority GPIO interrupt would be nice. Or do you think the GPIO_INPUT_GET function is too slow?
Thank you for any help
roc2
Postby roc2 » Thu Dec 15, 2016 3:02 pm
:D hi, is this question solved, and how to solve it?
roc2
Postby roc2 » Thu Dec 15, 2016 3:04 pm
dkaufmann wrote:Hi,
Hi,is your problem solved and how to solve this question??
Users browsing this forum: Google [Bot] and 2 guests
