[ESP8266] SoftAP Config
Postby ESP_Faye » Fri Feb 27, 2015 4:38 pm
:idea: :idea: :idea:
Sample code below is based on ESP8266_NONOS_SDK.
Set SSID, password and other information about ESP8266 soft-AP.
Download blank.bin to flash for initialization.
Please notice that wifi_softap_get_config(&softap_config); // Get config first is recommended to be called first.
Or you have to set value for every parameter in softap_config, for example, softap_config.beacon_interval and softap_config.ssid_len, otherwise they will be random value which may make ESP8266 softAP hardly to be connected.
 * FunctionName : user_set_softap_config
 * Description  : set SSID and password of ESP8266 softAP
 * Parameters   : none
 * Returns      : none
void ICACHE_FLASH_ATTR
user_set_softap_config(void)
   struct softap_config config;
   wifi_softap_get_config(&config); // Get config first.
   os_memset(config.ssid, 0, 32);
   os_memset(config.password, 0, 64);
   os_memcpy(config.ssid, "ESP8266", 7);
   os_memcpy(config.password, "12345678", 8);
   config.ssid_len = 0;// or its actual length
   config.beacon_interval = 100;
   config.max_connection = 4; // how many stations can connect to ESP8266 softAP at most.
   wifi_softap_set_config(&config);// Set ESP8266 softap config .
 * FunctionName : user_init
 * Parameters   : none
 * Returns      : none
void user_init(void)
    wifi_set_opmode(SOFTAP_MODE);
    // ESP8266 softAP set config.
    user_set_softap_config();
disideris
Re: [ESP8266] SoftAP Config
Postby disideris » Thu Jun 23, 2016 10:01 pm
i see the essid and when i put the password doesn't connect.
I am trying to connect to wifi with an iphone. Does that produce a specific problem?
design444
Postby design444 » Fri Jan 20, 2017 5:46 pm
thank you for sharing this information.I would really like to visit your website.thank you so much.its code is helpful for me .
i appreciated for this post.thank you
Layla508
Postby Layla508 » Fri Jan 20, 2017 9:04 pm
Thanks for the post! I`ll visit this website. It may be useful for my colleagues.
