模块异常复位,输出 ets Jan 8 2013,rst cause:1, boot mode:(3,6)
朝花夕拾
Postby 朝花夕拾 » Tue Nov 14, 2017 2:27 pm
买的安可信的串口wifi模块, esp8266;可是发现在运行过程中,经常会出现复位异常的情况;
Ai-Thinker Technology Co. Ltd.
ready
AT
AT+GMR
AT version:1.1.0.0(May 11 2016 18:09:56)
SDK version:1.5.4(baaeaebb)
Jun 13 2016 11:29:20
tail 0
chksum 0x63
tail 0
chksum 0x02
tail 0
chksum 0x79
csum 0x79
2nd boot version : 1.5
SPI Speed : 40MHz
SPI Mode : DIO
jump to run user1 @ 1000
屸r抣宭? 靗`屸r抣靗? l`屸r抣 帪宐r| 巄p?抌bb祢n顎nn? ll噔l鞄?l寧ll寣鞂l帋l€n
ready
交叉验证下来,感觉和MCU主板控制有关,请问有什么好的建议么?我看控制也比较简单;
VCC3.3V /Reset/ EN/TX/RX ;这5个引脚会引起如上异常么?
Her Majesty
Re: 模块异常复位,输出 ets Jan 8 2013,rst cause:1, boot mode:(3,6)
Postby Her Majesty » Tue Nov 14, 2017 3:23 pm
啥事也没做,就会复位么?这应该是硬件问题吧。。
朝花夕拾
Postby 朝花夕拾 » Tue Nov 14, 2017 3:53 pm
Her Majesty wrote:啥事也没做,就会复位么?这应该是硬件问题吧。。
是的,我也是这么认为,可是目前也找不出线索; :(
朝花夕拾
Postby 朝花夕拾 » Tue Nov 14, 2017 4:42 pm
我通过AT指令软件复位,和异常比较像,就是 boot mode后面的参数不同,异常是6,AT指令复位是7,
AT+RST
tail 0
chksum 0x63
tail 0
chksum 0x02
tail 0
chksum 0x79
csum 0x79
SPI Speed : 40MHz
SPI Mode : DIO
屸r抣宭? 靗`屸r抣靗? l`屸r抣 帪?抌bb祢n顎nn? ll噔l鞄?l寧ll寣鞂l帋l€nlrl
ready
朝花夕拾
Postby 朝花夕拾 » Wed Nov 15, 2017 9:53 am
今天早上抓取到的log;
论坛上有说是GPIO15有关;
http://blog.csdn.net/chen244798611/arti ... s/51636058
"I?;鼧2y?(执?2鰄#骬bh:?KhP??萷e??:均?Z1笰弛"Z???1I0浝EG?_9?F?蓯)?R(??閴8?丐!?Y???!*喞
8?
R4?鱂?U3rll湠|宭鄚 ?l?b|巶?抮抌l b岒nn瀕nn溾?bp鞄lrlrlp騨? ?l b n鈢l l帋b岒nn?l寧l`?nn l`nr帓抧 忪l`p騨? r寽溾? b n鈢?帋巄岒nn? l`?nn l`nr帓抧 宭`p騨? r寽溾囔l b n鈢l巖?b岒nn? l`?nn l`nr帓抧 騦l`r拻n 騦l`rl寣n湆騨n瀸炩宺nnn?l宐rrl ?抣?拻? ? 巐ll~rl ?抣lln溾 ? 悓~抈 ?抣寪n鄮n鞉n~寣ll鄝b llpb?br倢靗`nl巔岇l`bl`l拻n 瀗寬鈔l瀨b l l`rlrl巶r?
ready
AT
AT+GMR
AT version:0.60.0.0(Jan 29 2016 15:10:17)
SDK version:1.5.2(7eee54f4)
May 5 2016 17:30:30
AT+CWMODE=3
AT+CIPMUX=1
AT+CIPDINFO=1
AT+CIPSTAMAC_CUR?
+CIPSTAMAC_CUR:"5c:cf:7f:c7:9d:28"
AT+CIPAPMAC_CUR?
+CIPAPMAC_CUR:"5e:cf:7f:c7:9d:28"
AT+CIPSTA_CUR?
+CIPSTA_CUR:ip:"0.0.0.0"
+CIPSTA_CUR:gateway:"0.0.0.0"
+CIPSTA_CUR:netmask:"0.0.0.0"
AT+CIPAP_CUR?
+CIPAP_CUR:ip:"192.168.4.1"
+CIPAP_CUR:gateway:"192.168.4.1"
+CIPAP_CUR:netmask:"255.255.255.0"
AT+CWSAP_CUR?
+CWSAP_CUR:"AI-THINKER_C79D28","",1,0,4,0
AT+CIPAPMAC_CUR?
AT+CWSAP_CUR="ZT-2200011","12345678,1,0
tail 0
chksum 0x63
tail 0
chksum 0x02
tail 0
chksum 0x79
csum 0x79
SPI Speed : 40MHz
SPI Mode : DIO
rl?俽l尀鈱b l?
ready
tail 0
chksum 0x63
tail 0
chksum 0x02
tail 0
chksum 0x79
csum 0x79
SPI Speed : 40MHz
SPI Mode : DIO
rl巶rl尀鈱b l?
ready
wdt reset
tail 0
chksum 0x63
tail 0
chksum 0x02
tail 0
chksum 0x79
csum 0x79
SPI Speed : 40MHz
SPI Mode : DIO
rl巶rl尀鈱b l?
ready
wdt reset
tail 0
chksum 0x63
tail 0
chksum 0x02
tail 0
chksum 0x79
csum 0x79
SPI Speed : 40MHz
SPI Mode : DIO
rl巶rl尀鈱b l?
ready
wdt reset
tail 0
chksum 0x63
tail 0
chksum 0x02
tail 0
chksum 0x79
csum 0x79
SPI Speed : 40MHz
SPI Mode : DIO
rl巶rl尀鈱b l?
ready
wdt reset
tail 0
chksum 0x63
tail 0
chksum 0x02
tail 0
chksum 0x79
csum 0x79
SPI Speed : 40MHz
SPI Mode : DIO
rl巶rl尀鈱b l?
ready
wdt reset
tail 0
chksum 0x63
tail 0
chksum 0x02
tail 0
chksum 0x79
csum 0x79
SPI Speed : 40MHz
SPI Mode : DIO
rl巶rl尀鈱b l?
ready
YimingLi
Postby YimingLi » Thu Nov 16, 2017 5:56 am
你这个问题的定位,可能不用这么复杂。 乐鑫这个方案本身就提供了很好的调试定位提示,我们可以好好利用乐鑫提供的这些“福利”。
1、观察现象,注意到了你的复位提示都有这句话 "rst cause:1"
(1)这句话的意思是,你上一次的复位是“上电复位”,不是nRESET管脚复位或其他复位。
(2)考虑到软件复位看门狗复位等复位方式,不会改变这里的 rst cause而保留前一次复位的rst cause
2、所以,你这里复位的原因可能性为:
(1)模块在执行的过程中耗电过多超过了底板的供电能力,而上电复位了。
这里的原因,可能是底板的供电能力不够, 也可能是模块哪里虚短或者某个操作导致耗电过多所致。你提到了是使用安信可的模块,这个模块本身在某些基础的逻辑设计、供电、高速走线、以及射频天线等硬件设计方面,的确有一些值得进一步优化的地方,所以,我们经常会看到,在使用安信可的模块时,被要求“单独供电”或者要求给足够的供电。但实际上,乐鑫的芯片本身耗电不高,做出来的模块,一般只需要不到100mA足够发射了。但是对于安信可的模块,则往往“可能”需要提供150甚至200mA甚至更高的供电,否则,在通信的过程中,一开始发射就会容易出现掉线或复位等现象。所以,你可以试一试增强外部供电。
( 2)你的固件代码里有bug,或者模块的硬件有bug,导致某个固件执行耗时太多或者出现异常,导致模块出现了看门狗复位或其他类似的软件复位方式。
3、你可以执行下面的实验建议,进一步缩小定位原因(如果你通过简单的增强供电或单独供电无法解决):
(1)如果你的这个复位现象很容易复现;那么,你可以通过 nRST管脚对模块进行一次复位(不要再上电复位),你可以看到rst cause后面的数值为2. 接着你再去复现你这里的复位问题,再观察等到故障复位时的rst cause后面的数值为多少。如果这里的数值继续为2,那就可以排除是上面的原因可能性(1),而是上面的原因可能性(2)了,因为看门狗或软件复位等原因导致的模块复位(rst cause保留了之前的 数值)。如果此时你复现出问题时,rst cause 变成了1,也就是说,改变了之前的数值2,那么你这里的复位问题,就是上面的原因可能性1了。
或者
(2)如果你能修改固件,你可以在固件代码的最初初始化阶段,调用一个API函数,可以在初始阶段进一步打印出复位的原因,如下所示的定制性启动提示。最初一部分,是片上boot的打印提示,里面有rst cause:1。后半部分是user_init()里的打印输出, 注意到其中有一句: .reset reason :4, soft restart。这个就是调用乐鑫标准的SDK API进一步输出复位原因的结果。实际上,我这个例子,也是我执行AT+RST命令的结果。
供参考,希望可以帮到你。
<<<<< Module reboot 2017-11-16.05:29:37 >>>>>>
tail 8
chksum 0xe5
tail 8
chksum 0x84
tail 8
chksum 0xd8
csum 0xd8
2nd boot version : 1.6
SPI Speed : 40MHz
SPI Mode : QIO
jump to run user1
MBytes/s+ High-Speed Wifi module on esp8266ex by AnyLinkin!, 2015.5-
.taobao : https://item.taobao.com/item.htm?id=550946928238
.email : IoT@anylinkin.com
.esp cpu freq : 160MHz
.reset reason : 4, soft restart
.power saving : 2, moderate sleep
.esp chipid : 0x000DAAB2
.esp wifi mac : EC-C7-00-0D-AA-B2
.flashid : 0x001540EF, Winbond ,2MBytes QIO
.wifi phy mode : 802.11n
.wifi fixed rate : disabled
.wifi limit rate : none
.APs recorded : 1
.esp sdk ver : 1.5.4.1(39cb9a32)
.app ver : 1.1.5-ETx(H)
.app features :support Espressif AT Standard
support Anylinkin AT Extended
support SPI High Speed (Over MBytes/s)
support Web Server & local DNS
support crypto & signature
support Gizwits On UART AT / SPI API
.compile time :2017-10-15 19:50:40
.free heap size : 0x6780 / 26496
ready
Users browsing this forum: beegee1962, f4568525153 and 3 guests
