ESP8266 AES256 / firmware protection / encrypted bootcode
Posted: Tue Jun 30, 2015 4:08 am
by rudi
my name is rudi and i come from germany.
I will show you as preview my works last weeks in this now.
I will update the uncuted videos asap - sorry for the qualitity.
Webserver with AES256
you will be identify encrypted ;-)
protected AT Version with AES256
you can communicate in AES256 over UART, SPI, I2C, (H)SPI and more
AT Commands for testings..
protected developer key AT+GMR and more extended security tags
this will be a must have - and if you use - you will never missed - i am sure
i work with this for Industry 4.0 Apps and more ( database application mesh network with auto configured esp8266 for P2P automation .. ( > 500 pcs )
LIB: ... ibaes256.a
with an own bootloader i boot in an asap comming project
from sd card part of encrypted bootcode (firmware) ( copy protected part )
and transfer it to iram... protected and run this mapped/direct :)
details for this only you give me gift, wifes, cars, (drugs-no this is bad!) , rockn roll and other good things :) :)
fun! ;-) will ´think about this .. but just in time - only libs because this is many month work in bootcode and more -
ESP8266 goes AES256 now with own bootcode
best wishes
rudi ;-)
and yes
will post all here as a small project and describe all fine.
please be patient, i am work at other project until this weekend
and then i will update all here with all docu step by step , examples and more.
feel free for google search: ESP8266 AES256
The first you will find - is the best german Forum where i be 'at Home'
greetings fly out to friends all over the globe
my base was:
Free AES256 ECB Implantation
will post more and a sample project next time.
Re: ESP8266 AES256 / firmware protection / encrypted bootcode
Posted: Fri Aug 28, 2015 10:21 pm
by rudi
small Continued:
have you a short time at you tube?
have phun:
1st step was done:
i tested an open src bootloader named 'rboot'
i extended open src Bootloader with AES256 support in a test (aes256.a)
user firmware is on the SDHC
next step:
- 2) user firmware is encrypted on the SDHC and will decrypt on the fly
- 3) bootloader is on sdhc and esp will boot from sd card without flash ic
- 4) ;-) be surprised!
continued Description and final code will follows later time with a projekt.
best wishes
rudi ;-)
info: opens src bootloader
rBoot is designed to be a flexible open source boot loader, a replacement for
the binary blob supplied with the SDK. It has the following advantages over the
Espressif loader:
- Open source (written in C) ;-)
- Supports up to 256 roms. ;-)
- Roms can be variable size. ;-)
- Able to test multiple roms to find a valid backup (without resetting). ;-)
- Flash layout can be changed on the fly (with care and appropriately linked ;-)
rom images).
- GPIO support for rom selection. ;-)
- Wastes no stack space (SDK boot loader uses 144 bytes). ;-)
- Documented config structure to allow easy editing from user code. ;-)
- Can validate .irom0.text section with checksum. ;-)
Posted: Fri Jul 14, 2017 8:01 pm
by Hanspebram
Hello Colin,
this looks interesting. In your source OneWire.h is included.
I cannot find it for ESP32 somewhere. Could you please help ?
