"Non-atomic" +CIPSEND bug
Rst7
Postby Rst7 » Thu Oct 27, 2016 8:54 pm
I have a problem with reopen socket until data transfer performed.
For example:
Send to ESP: AT+CIPSEND=1,xxx\r\n
Receive from ESP: OK\r\n
Receive from ESP: >
Send to ESP: ...some...data... (first portion of data)
Receive from ESP: 1,CLOSED\r\n (remote client close connection when data transfered to internal buffer of ESP)
Send to ESP: ...some...data... (next portion of data)
Receive from ESP: 1,CONNECTED\r\n (remote client open new connection when data transfered)
Send to ESP ...some...data... (last portion of data, all data sended)
Receive from ESP: SEND OK\r\n
In this case all data for the old connection sent in new connection.
What can I do with this?
Thank you.
Re: "Non-atomic" +CIPSEND bug
Postby Her Majesty » Fri Mar 24, 2017 2:19 pm
Message "CLOSE" means the connection is closed, you should stop sending data.
Detect message "CONNECTED" to start a new transmission.
朝花夕拾
Postby 朝花夕拾 » Fri Dec 22, 2017 4:48 pm
Her Majesty wrote:Message "CLOSE" means the connection is closed, you should stop sending data.
hi,majesty;
you say ,"CLOSE" means the connection is closed,but i want know why the connection closed ?
i know some reasons,such as ;
1 the tcp server could close connection;
2 mcu could send AT cmd to esp8266 ,close connection;
Is there any other reason ?
Postby Her Majesty » Mon Dec 25, 2017 2:37 pm
Hi, yes, the TCP connection could be ended by the server or the client, you can capture the TCP packets (by omnipeek or wireshark) to check the reason of disconnection.
