How to flash the ssl certificate
ronakshah
Postby ronakshah » Fri May 26, 2017 6:00 pm
I want to use the SSL connection using the pre complied AT command image.
They provide the AT command to open ssl connection.
So how I download the SSL certificate.
As mention in the previous post -we need to use the programmer to load the certificate.
so which address I need to use.
Provide the detailed description of using SSL with certificate using AT command
Re: How to flash the ssl certificate
Postby Her Majesty » Wed Jun 28, 2017 5:03 pm
For all I know, AT cannot use the SSL certificate due to the memory limitation.
