+IPD command lacking LF ??
Posted: Mon Sep 04, 2017 6:43 pm
by sebastian.heyn
I noticed, when receiving data using the TCP server, normally all strings sent by the ESP8266 use CR+LF
However, the +IPD only outputs the CR (0A) and the LF (0D) is missing. Any hints??
030 ,2C C43 O4F N4E N4E E45 C43 T54  0D  0A
0D  0A
+2B I49 P50 D44 ,2C 030 ,2C 535 :3A T54 e65 s73 t74  0A
030 ,2C C43 L4C O4F S53 E45 D44  0D  0A
Re: +IPD command lacking LF ??
Posted: Tue Sep 05, 2017 4:39 pm
by pratik
Can you let me know which firmware version you are using?
You can find out using AT+GMR
