[SOLVED] AT+UART_DEF not keeped in memory after reboot
Eliott
Postby Eliott » Wed Oct 11, 2017 6:32 am
when I use the command
AT+UART_DEF=xxxx,8,1,0,0<CR><LF>
my device is immediately at the good baurdate but when I reboot it the last baudrate is set.
Sometime the baudrate is at the good value afte reseting but in random cases.
Do I have to wait or send other command to set the baudrate defenitely ?
This is a bug ?
AT version:1.4.0.0(May 5 2017 16:10:59)<CR><LF>
SDK version:2.1.0(116b762)<CR><LF>
compile time:May 5 2017 16:37:48<CR><LF>
Eliott.
Re: AT+UART_DEF not keeped in memory after reboot
Postby Her Mary » Wed Oct 11, 2017 1:36 pm
Maybe due to the flash size mismatching.
Which bin files are downloaded into your flash, and have you selected the correct flash size while downloading?
Eliott
Postby Eliott » Thu Oct 12, 2017 1:07 am
I usually flash with a 4Mbit flash instead of 32Mbit as mounted.
With the correct flash configutation size an binary the baudrate stay configured.
But I don't know what I miss because now I'm unable to change DHCP configuration and I got very strange IP:
AT<CR><LF>
AT<CR><LF>
<CR><LF>
OK<CR><LF>
AT+GMR<CR><LF>
AT+GMR<CR><LF>
compile time:May  5 2017 16:37:53<CR><LF>
OK<CR><LF>
AT+CWDHCP_DEF=0,1<CR><LF>
<CR><LF>
ERROR<CR><LF>
AT+CWDHCPS_DEF?<CR><LF>
+CWDHCPS_DEF:0,0.0.0.0,0.0.0.0<CR><LF>
OK<CR><LF>
AT+CWLAP<CR><LF>
AT+CWLAP<CR><LF>
+CWLAP:(4,"Livebox-EE7A",-75,"f4:6b:ef:20:ee:7a",1,-94,0)<CR><LF>
+CWLAP:(3,"FreeBox_Hutin",-80,"00:24:d4:c9:95:6c",4,-105,0)<CR><LF>
+CWLAP:(0,"FreeWifi",-80,"00:24:d4:c9:95:6d",4,-105,0)<CR><LF>
+CWLAP:(5,"FreeWifi_secure",-80,"00:24:d4:c9:95:6e",4,-105,0)<CR><LF>
+CWLAP:(3,"Livebox-B968",-84,"ac:84:c9:13:b9:68",6,-86,0)<CR><LF>
+CWLAP:(2,"SFR_8320",-88,"44:ce:7d:7e:83:24",6,-71,0)<CR><LF>
+CWLAP:(4,"4G-TPLINK",-64,"10:fe:ed:e6:7c:04",9,-105,0)<CR><LF>
+CWLAP:(4,"Livebox-6EFE",-89,"f4:6b:ef:12:6e:fe",11,-94,0)<CR><LF>
<CR><LF>
OK<CR><LF>
AT+CWJAP_DEF="4G-TPLINK","gjpw4PC72D86xht","10:FE:ED:E6:7C:04"<CR><LF>
AT+CWJAP_DEF="4G-TPLINK","xxxx","10:FE:ED:E6:7C:04"<CR><LF>
WIFI CONNECTED<CR><LF>
WIFI GOT IP<CR><LF>
<CR><LF>
OK<CR><LF>
AT+CIPSTA?<CR><LF>
AT+CIPSTA?<CR><LF>
+CIPSTA:ip:"52.71.45.84"<CR><LF>
+CIPSTA:gateway:"52.71.45.1"<CR><LF>
+CIPSTA:netmask:"255.255.255.0"<CR><LF>
<CR><LF>
OK<CR><LF>
Thank you for help.
Eliott.
Postby Her Mary » Thu Oct 12, 2017 3:17 pm
Try "AT+RESTORE" command to initialize first before testing. It always can solve some strange problems.
Eliott
Postby Eliott » Fri Oct 13, 2017 5:15 am
Solved !
Thank you very much.
Eliott.
