ESP8266 Sends UDP data
Postby ESP_Faye » Tue May 12, 2015 5:55 pm
If using espconn in ESP8266_RTOS_SDK, please call espconn_init in user_init as initialization.
     * Copyright 2013-2014 Espressif Systems
#include "ets_sys.h"
#include "os_type.h"
#include "osapi.h"
#include "mem.h"
#include "user_interface.h"
#include "espconn.h"
#include "user_json.h"
#include "user_devicefind.h"
LOCAL os_timer_t test_timer;
LOCAL struct espconn user_udp_espconn;
const char *ESP8266_MSG = "I'm ESP8266 ";
LOCAL struct espconn ptrespconn;
  * FunctionName : user_udp_recv_cb
  * Description  : Processing the received udp packet
  *                pusrdata -- The received data (or NULL when the connection has been closed!)
  *                length -- The length of received data
  * Returns      : none
 LOCAL void ICACHE_FLASH_ATTR
 user_udp_recv_cb(void *arg, char *pusrdata, unsigned short length)
     os_printf("recv udp data: %s\n", pusrdata);
      * FunctionName : user_udp_send
      * Description  : udp send data
      * Parameters  : none
      * Returns      : none
 user_udp_send(void)
     char DeviceBuffer[40] = {0};
     char hwaddr[6];
     struct ip_info ipconfig;
     const char udp_remote_ip[4] = { 255, 255, 255, 255};
     os_memcpy(user_udp_espconn.proto.udp->remote_ip, udp_remote_ip, 4); // ESP8266 udp remote IP need to be set everytime we call espconn_sent
     user_udp_espconn.proto.udp->remote_port = 1112;  // ESP8266 udp remote port need to be set everytime we call espconn_sent
     wifi_get_macaddr(STATION_IF, hwaddr);
     os_sprintf(DeviceBuffer, "%s" MACSTR "!" , ESP8266_MSG, MAC2STR(hwaddr));
     espconn_sent(&user_udp_espconn, DeviceBuffer, os_strlen(DeviceBuffer));
      * FunctionName : user_udp_sent_cb
      * Description  : udp sent successfully
      * Returns      : none
  user_udp_sent_cb(void *arg)
      os_printf("user_udp_send successfully !!!\n");
      //disarm timer first
       os_timer_disarm(&test_timer);
      //re-arm timer to check ip
      os_timer_setfn(&test_timer, (os_timer_func_t *)user_udp_send, NULL); // only send next packet after prev packet sent successfully
      os_timer_arm(&test_timer, 1000, 0);
 * FunctionName : user_check_ip
 * Parameters   : none
 * Returns      : none
user_check_ip(void)
    if (wifi_station_get_connect_status() == STATION_GOT_IP && ipconfig.ip.addr != 0)
      os_printf("got ip !!! \r\n");
      wifi_set_broadcast_if(STATIONAP_MODE); // send UDP broadcast from both station and soft-AP interface
      user_udp_espconn.type = ESPCONN_UDP;
      user_udp_espconn.proto.udp = (esp_udp *)os_zalloc(sizeof(esp_udp));
      user_udp_espconn.proto.udp->local_port = espconn_port();  // set a available  port
      const char udp_remote_ip[4] = {255, 255, 255, 255};
      espconn_regist_recvcb(&user_udp_espconn, user_udp_recv_cb); // register a udp packet receiving callback
      espconn_regist_sentcb(&user_udp_espconn, user_udp_sent_cb); // register a udp packet sent callback
      espconn_create(&user_udp_espconn);   // create udp
      user_udp_send();   // send udp data
   else
                wifi_station_get_connect_status() == STATION_CONNECT_FAIL))
         os_printf("connect fail !!! \r\n");
      else
            os_timer_setfn(&test_timer, (os_timer_func_t *)user_check_ip, NULL);
 * Parameters   : none
 * Returns      : none
user_set_station_config(void)
   // Wifi configuration
   char ssid[32] = SSID;
   char password[64] = PASSWORD;
   //need not mac address
   stationConf.bssid_set = 0;
   //Set ap settings
   //set a timer to check whether got ip from router succeed or not.
 * FunctionName : user_init
 * Parameters   : none
 * Returns      : none
void user_init(void)
   //Set softAP + station mode
   //ESP8266 connect to router
   user_set_station_config();
If you want to send back a response when received one,
     struct espconn *pesp_conn = arg;
       remot_info *premot = NULL;
       sint8 value = ESPCONN_OK;
       if (espconn_get_connection_info(pesp_conn,&premot,0) == ESPCONN_OK){
             pesp_conn->proto.udp->remote_port = premot->remote_port;
             pesp_conn->proto.udp->remote_ip[0] = premot->remote_ip[0];
             pesp_conn->proto.udp->remote_ip[1] = premot->remote_ip[1];
             pesp_conn->proto.udp->remote_ip[2] = premot->remote_ip[2];
             pesp_conn->proto.udp->remote_ip[3] = premot->remote_ip[3];
             espconn_sent(pesp_conn, pusrdata, os_strlen(pusrdata));
usd18290
Re: ESP8266 Sends UDP data
Postby usd18290 » Mon May 23, 2016 8:35 pm
I think the response code got issue. The proto should be udp instead of tcp, right ?
Postby ESP_Faye » Tue May 24, 2016 10:03 am
Thanks! We revised it.
semlanik
Postby semlanik » Thu Jan 11, 2018 8:12 pm
Hi all,
I'm trying the similar thing in my network but using station instead of AP. And it doesn't work. I also tried calculate broadcast address accordding IP and mask it doesn't work as well. But send to particular IP works fine.
Any ideas of this behaivor?
I'm using non-os SDK 2.1.x.
Alexey.
Postby Her Mary » Mon Jan 15, 2018 3:14 pm
Try station_only mode when calling wifi_set_opmode. And also call wifi_set_broadcast_if (STATION_MODE); to enable broadcast in the station mode.
coright
Postby coright » Wed Jun 13, 2018 5:09 pm
does ESP8266_RTOS_SDK support UDP broadcast?
Postby Her Mary » Fri Jun 15, 2018 9:35 am
You can use socket directly on RTOS SDK. I think it should support UDP broadcast.
SariaHom
Postby SariaHom » Fri Oct 18, 2019 10:09 am
I try to make file transfer over UDP. I use Indy UDP Server TIdUDPServer as sender and Indy UDP Client TIdUDPClient as receiver. Or UDP Server TIdUDPServer as sender and as receiver on "client part". First at all receiver sends request for some file, and if it exist on senders part, the sender send response that the file exist.
Then receiver request some file part from sender, and after receiving sends receiving confirmation. Sender wait for the confirmation and another request for other part.
I need to keep possibility to receive data/file from different sources.
So, after receiving request sender open required file
if OpenDialog1->Execute
String FName=OpenDialog1->Filename;
etc...
After receiving all the parts receiver seve it using SaveDialog.
Please, could you show me how to make sending file part by part, each part upon a request. As an example each part = 256 kb. How to send requests to different transmitters, wait for the required parts, make confirmation sending and save file after receiving.
I think after receiving file request from receiver each sender sends response file<ID> exist, <FileSize>, <Parts count>, <Something else... probably>. - it just a String. In case if file wasnt found - another response... Receiver count all received parts to make sure if all of them was received.
Please show me some samples or let me know how to use this INDY components. As Software development tool I use Embarcadero XE7. C
Thank you.
