ESP8266 - GOOGLE CLOUD MESSAGING WITHOUT EXTERNAL SERVER
Posted: Mon Feb 01, 2016 5:33 pm
by beegee1962
I was looking into a solution to send push notifications from an ESP8266 module to an Android application. I know that this is possible with the Google Cloud Messaging service.
But what I found on the internet is using an external webserver, able to run PHP (or Python) scripts and using a MySQL server to store registration IDs.
So far so good, but why do I need to setup an external server with MySQL and PHP just to send messages to the Android devices. The ESP8266 has server capabilities build-in and has enough storage to save registration IDs in the Flash memory.
What I wanted is:
As I could not find any tutorial or example on the Internet how to achieve this, I started to write the code by myself.
And here is the result:
ESP8266 - Google Cloud Messaging without external server
Of course the code is open source and stored in my Github repository
Hope it helps someone.
Re: ESP8266 - GOOGLE CLOUD MESSAGING WITHOUT EXTERNAL SERVER
Posted: Tue Feb 02, 2016 5:17 pm
by wuyunzhou
good job.
yes, if the device can get the gcm api_key, and the android registration id, the device can notify without server.
so the first is to pass the android registration id from app to device,
then make a http request to Gcm server, like this:
POST /gcm/send HTTP/1.1
User-Agent: curl/7.22.0 (x86_64-pc-linux-gnu) libcurl/7.22.0 OpenSSL/1.0.1 zlib/1.2.3.4 libidn/1.23 librtmp/2.3
Host: gcm-http.googleapis.com
Accept: */*
Authorization: key=${api_key}
Content-Type: application/json
Content-Length: xx
{"registration_ids":%s,"priority":"%s","time_to_live":%s,"data":%s}
registration_ids is a array with android registration ids.
Posted: Tue Feb 02, 2016 8:26 pm
by beegee1962
wuyunzhou,
Correct, that is how it works. However I didn't use the "priority" and "time_to_live' keys.
ESP8266 GOOGLE CLOUD MESSAGING WITHOUT EXTERNAL SERVER
Posted: Mon May 22, 2017 4:09 pm
by JamesRit
Hi. copying the form of the sample in my test project, allways get the error google is not defined. I can run the sample avobe with no problem, but with my test project, allways the same error. I dont konw why. Thanks.
