ESP8266 creates a UDP listening
Postby ESP_Faye » Sat Feb 28, 2015 2:45 pm
:idea: :idea: :idea:
If using espconn in ESP8266_RTOS_SDK, please call espconn_init in user_init as initialization.
Create a UDP listening on ESP8266,if ESP8266 got UDP message "Are You ESP8266 Device?",it will response "Yes,I'm ESP8266!" with its MAC address and IP address
 * Copyright 2013-2014 Espressif Systems
#include "ets_sys.h"
#include "os_type.h"
#include "osapi.h"
#include "mem.h"
#include "user_interface.h"
#include "espconn.h"
#include "user_json.h"
#include "user_devicefind.h"
const char *device_find_request = "Are You ESP8266 Device?";
const char *device_find_response_ok = "Yes,I'm ESP8266!";
LOCAL struct espconn ptrespconn;
 * FunctionName : user_devicefind_recv
 * Description  : Processing the received udp packet
 *                pusrdata -- The received data (or NULL when the connection has been closed!)
 *                length -- The length of received data
 * Returns      : none
LOCAL void ICACHE_FLASH_ATTR
user_udp_recv(void *arg, char *pusrdata, unsigned short length)
    char DeviceBuffer[40] = {0};
    char Device_mac_buffer[60] = {0};
    char hwaddr[6];
    struct ip_info ipconfig;
    if (wifi_get_opmode() != STATION_MODE)
        wifi_get_ip_info(SOFTAP_IF, &ipconfig);
        wifi_get_macaddr(SOFTAP_IF, hwaddr);
        if (!ip_addr_netcmp((struct ip_addr *)ptrespconn.proto.udp->remote_ip, &ipconfig.ip, &ipconfig.netmask))
         //udp packet is received from ESP8266 station
            wifi_get_macaddr(STATION_IF, hwaddr);
      else
         //udp packet is received from ESP8266 softAP
   else
    if (pusrdata == NULL)
        return;
    if (length == os_strlen(device_find_request) &&
            os_strncmp(pusrdata, device_find_request, os_strlen(device_find_request)) == 0)
        //received device find message
        os_sprintf(DeviceBuffer, "%s" MACSTR " " IPSTR, device_find_response_ok,
                   MAC2STR(hwaddr), IP2STR(&ipconfig.ip));
        os_printf("%s\n", DeviceBuffer);
        length = os_strlen(DeviceBuffer);
      //if received "Are You ESP8266 ?" , response "Yes,I'm ESP8266!" + ESP8266 mac + ESP8266 ip
        espconn_sent(&ptrespconn, DeviceBuffer, length);
   else
      //received some other data
 * FunctionName : user_devicefind_init
 * Description  : create a udp listening
 * Parameters   : none
 * Returns      : none
user_udp_init(void)
    ptrespconn.type = ESPCONN_UDP;
    ptrespconn.proto.udp = (esp_udp *)os_zalloc(sizeof(esp_udp));
    ptrespconn.proto.udp->local_port = 1025;  // ESP8266 udp port
    espconn_regist_recvcb(&ptrespconn, user_udp_recv); // register a udp packet receiving callback
    espconn_create(&ptrespconn);   // create udp
 * FunctionName : user_init
 * Parameters   : none
 * Returns      : none
void user_init(void)
   //Set softAP + station mode
   // Create udp listening.
   user_udp_init();
esp8266ac
Re: ESP8266 creates a UDP listening
Postby esp8266ac » Fri Feb 19, 2016 12:49 am
能否提供基于RTOS SDK上的sample code?
beyondhong
Postby beyondhong » Tue Sep 27, 2016 11:28 am
there's more jobs to be done in the sample code
espconn_get_connection_info should be invoked in user_udp_recv before ip_addr_netcmp
and reset the remote_ip & remote_port
mike.wu
Postby mike.wu » Wed Nov 09, 2016 5:21 pm
esp8266ac wrote:能否提供基于RTOS SDK上的sample code?
在RTOS上我遇到的情况是espconn_init()调用后,不停的重启。不如直接用include/lwip下的lwip来直接实现,就跟socket编程一样。 :D
