Pull up resistors
BuGless
Pull up resistors
Postby BuGless » Wed Sep 09, 2015 2:52 am
In the pin specs I see wpu and wpd. I presume that means weak-pull-up and weak-pull-down respectively.
What are the specs on those wpu and wpd resistors?
Espressif_Kelly
Re: Pull up resistors
Postby Espressif_Kelly » Wed Oct 14, 2015 11:27 am
Dear BuGless,
The value of internal pull-up resistor is between 30Kohm and 100Kohm.
Below is the descriptions of GPIO that you can refer to.
MStylesMS
Postby MStylesMS » Wed Sep 27, 2017 10:28 pm
Espressif_Kelly thank you for the info. Is there a list of pull up resistor value by GPIO?
Users browsing this forum: Yahoo [Bot] and 4 guests
