FCC problem - Spectrum analyzer shows unwanted transmission when startup
DreeOlee
Postby DreeOlee » Wed Jan 10, 2018 9:31 pm
Hello everyone,
This is my first post at this Forum. Hopefully someone can help/support me with this urgent issue.
The problem is that the module shows a lot of unwanted transmissions during start-up, causing the FCC certification to fail.
As the attachment shows, the transmissions are unexpected and not inside the FCC regulations. According the FCC, transmissions outside the blue lines are not allowed.
> I'm using the ESP-WROOM-02 module.
> Latest SDK (also tried previous versions)
> Even deleted every WiFi SDK link, without success
> Try starting up with WiFi disabled, no success
> Tried different power supplies, no success
> The phenomenon is also visible during a restart from deep sleep
> After restart, so from the first line of the initialization/setup(), I have full control without issues.
At this moment I'm out of ideas how to solve this problem. I expect it's a ESP hardware issue, but not sure.
Is there anyone who can help me with this or is there anyone who have seen this problem before?
Greetings,
DreeOlee
Re: FCC problem - Spectrum analyzer shows unwanted transmission when startup
Postby Her Majesty » Thu Jan 11, 2018 6:02 pm
Espressif provided an FCC firmware on their website http://www.espressif.com/en/support/download/other-tools.
You can download and test the "ESP8266 Certification and Test".
DreeOlee
Postby DreeOlee » Thu Jan 11, 2018 8:32 pm
I just downloaded the ESP8266_FCC_26m_20170731.bin file, and the result is exactly the same. Directly at power-up and just ones.
blubb
Postby blubb » Fri Jan 12, 2018 7:13 am
Have you tried the API mentioned here?
viewtopic.php?f=7&t=8768
DreeOlee
Postby DreeOlee » Fri Jan 12, 2018 5:12 pm
Yes I also tried that. In fact, that was our original problem. We made a change in the API and now we had full control over the ESP. But still the problem appears with switching the device on.
It happens only at startup. Just a fraction of time, after that there is no problem. The time is that short, that the spectrum analyzer not always captures the signal.
blubb
Postby blubb » Fri Jan 12, 2018 6:08 pm
Do you call this API in user_rf_pre_init or in user_init? I wonder if that makes a difference.
DreeOlee
Postby DreeOlee » Fri Jan 12, 2018 10:47 pm
In the user_init. Tried also in the user_rf_pre_init without result.
The problem occurs before the user_rf_pre_init. I commented everything out in the user_rf_pre_init, user_init and the init_done. Strange btw is that after this, I got more debug info on my serial line :D
 ets Jan  8 2013,rst cause:2, boot mode:(3,0)
tail 8
chksum 0x2d
csum 0x2d
v00000000
~ld
rf cal sector: 508
freq trace enable 0
rf[112] : 00
rf[113] : 00
rf[114] : 00
SDK ver: 2.1.0(deb1901) compiled @ Oct 23 2017 17:58:03
phy ver: 1136_0, pp ver: 10.2
mode : null
I still have the problem.
blubb
Postby blubb » Fri Jan 12, 2018 10:52 pm
I recommend opening an issue on github
https://github.com/espressif/ESP8266_NONOS_SDK/issues
Edit:
There are several APIs like
system_phy_set_powerup_option(...);
system_phy_freq_trace_enable(...);
But if the problem occurs before user_rf_pre_init this is a case for a github issue for sure.
DreeOlee
Postby DreeOlee » Fri Jan 12, 2018 11:08 pm
okay thank.....I will place it directly.
blubb
Postby blubb » Sat Jan 13, 2018 8:51 am
Maybe one more idea:
Did you flash the latest esp_init_data_default.bin?
Recently they changed something, so there is a new version "8":
https://github.com/espressif/ESP8266_NO ... master/bin
