esp8266 in proxy network
Posted: Wed Jan 23, 2019 3:29 pm
by sathishgkg
Hi
i have a esp8266 12e device, which can able to communicate with server in non proxy environment were i can able to send and receive data to and from server,
but in proxy server im not able to connect the internet,
is there any possibility to communicate to server in porxy network using esp8266 12e?.
If possible please let help us to do it.
Regards
imake
Re: esp8266 in proxy network
Posted: Fri Feb 15, 2019 2:17 pm
by neilwalker
I've been using ESP8266 to send data to the server. I guess it should be done with the HTTP GET commands. Where should I indicate proxy's parameters on the ESP8266? I contacted Vicne (found the question on esp8266 forum last minute essay), but no answer so far.
View first unread post
Posted: Mon Oct 07, 2019 9:20 pm
by FujiVob
I searched for fw20 and did not see anything that I was allowed to see, only one thing in the sale section or somthing which you need a post to view, so tada. Anyway, I have a fw20 deck and when you hit play on either side it usually spins but the left side of the tape just keeps getting eaten up, like maybe only on of the reels is spinning. anyone know how to fix this?
