Crystal Golf Solitaire
jihouni
Postby jihouni » Fri Sep 23, 2022 4:56 pm
Crystal Golf Solitaire is an engaging version of the card game. As always, your goal is to remove all the cards to get to the next round.
How to play:
Cards can be removed from the layout if they are higher or lower than a visible deck shown at the bottom. You can set the difficulty level of the game before starting. On the easiest setting, Aces are both high and low, allowing you to place a King or 2 pieces on them. Of the two harder settings, Aces are only low, so you can only play a 2 on them. The hardest setup also hides the card.
Joker can also be used. They can be played at any time, and any card can be placed on them, and can be particularly useful in creating longer card runs.
At the end of each round you will get bonus points for unused cards and a speed bonus.
Click the deck at the bottom to deal a new card. Crystal Golf Solitaire ends when there are no more moves left.
Play more card game at klondkie solitaire
Users browsing this forum: No registered users and 5 guests
