Cannot recover from Fatal exception (0): problem during boot
panaghs
Re: Cannot recover from Fatal exception (0): problem during boot
Postby panaghs » Sun Dec 18, 2016 8:29 am
Hello jemy hello espressif administrators,
I did not get any efuse-connected message... and I erased the whole flash memory several times with Pratik's trick. Do I have to use some later version than FLASH_DOWNLOAD_TOOLS_v2.4_150924 that I used? I also used NodeMCU firmware programmes and got normal flash results for all packages downloaded.
Doesn't make sense...
I am willing to send you the chip for checking and analysis. Would you like that?
Panagis
jemy
Postby jemy » Mon Dec 19, 2016 1:55 am
I use flash_download_tools_v3.4.4. the early version doesn't show Efuse error.
efuse is in the processor not flash. when it change it will change the function of the processor so you need different firmware for it to run.
you earsed flash memory but still flashed old firmware into it. so you got same result.
I try not to think the factory hide efuse in the chip could totally disable the chip. if that' the case would make me sad and angry.
panaghs
Postby panaghs » Fri Dec 23, 2016 10:59 pm
Unfortunatelly, I cannot use the laterversions. This is because the lowest possible flashing speed is 115200 and my esp syncs at 9600. Except if you know a way how to add the option of 9600 at the dropdown list...
Postby pratik » Tue Dec 27, 2016 11:06 pm
Hi!
Got the issue now in greater detail, thanks for the long post! I'll forward this and get feedback on the issue.
I'm sure now that it's no issue with the Electrical connection or supply.
I wonder if changing the flash chip will resolve this issue? I'll let you know soon.
panaghs
Postby panaghs » Wed Dec 28, 2016 12:17 am
Thank you Pratik. If you have any news, please, let me know.
Panagis
pezGordo
Postby pezGordo » Thu Jan 05, 2017 12:13 am
Hello, I'm suffering the same issue now
I can upload , delete flash
I've tried Arduino IDE, esptool.py (in Ubuntu), NodeMCU, NONOS
All 10K resistors are there (breadboard)
100nf capacitor near (into) esp12
still receiving response below
please any advice on how to solve is very appreciated, I have 10 of these and want to use them
 ets Jan  8 2013,rst cause:2, boot mode:(3,7)
load 0x40100000, len 1396, room 16
tail 4
chksum 0x89
load 0x3ffe8000, len 776, room 4
tail 4
chksum 0xe8
load 0x3ffe8308, len 540, room 4
tail 8
chksum 0xc0
csum 0xc0
2nd boot version : 1.4(b1)
  SPI Speed      : 40MHz
  SPI Mode       : QIO
  SPI Flash Size & Map: 4Mbit(256KB+256KB)
  jump to run user1 @ 1000
epc1=0x40201670, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
I can see ets Jan 8 2013,rst cause:2, boot mode:(3,6) , rst cause:2 impliing "reset pin" , but measuring reset pin I see it 3.3V steady
also, I can read SPI Flash Size & Map: 4Mbit(256KB+256KB), but it is suposed I'm using (512KB+512KB) bin/at/ folder of esp8266_nonos_sdk_v2.0.0_16_08_10
please help, thanks
ESP_Greg
Postby ESP_Greg » Thu Jan 12, 2017 11:18 am
Hi pezGordo,
You need select 8Mbit flash map at least. AT binary can't support less than 8Mbit flash map.
aditgupta100
Postby aditgupta100 » Fri Jan 13, 2017 1:54 am
For AT firmware use below address and configuration for ESP8266-01:
boot_v1.6.bin : 0X00000
esp_init_data_default.bin : 0XFC000
blank.bin : 0XFE000
user1.1024.new.2.bin : 0x1000
BAUD RATE : 115200
FLASH SIZE : 8MB
FLASH SPEED : 40MHz
SPI : QIO
This module is very sensitive i guess, because with above settings my module worked in AT but than in middle it might get to reset state (printing that fatal exception).
Even i'm facing same issue with NodeMCU. I'm able to run module with AT but what shall i do to run NodeMCU (Lua scripts on module) it gives same fatal exception (0) error (illegalInstructionCause) which probably is because of firmware not detected.
aditgupta100
Postby aditgupta100 » Fri Jan 13, 2017 2:12 am
ESP_Greg wrote:Hi pezGordo,
What is happening :
During time of flashing module i need to bring CH_PD HIGH -> LOW -> HIGH.
After this patchwork, I'm able to flash my module with tool and firmware
When i switch to programming mode, also i need to bring CH_PD HIGH -> LOW -> HIGH to boot the module
But during boot, with Esplorer/putty i'm getting
epc1=0x40210880, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
Hardware used :
ESP8266-01
Arduino is used for Power supply (3.3V) and UART
FIRMWARE/BINARIES INSTALLED :
nodemcu_integer_0.9.5_20150318.bin : 0X00000
blank.bin : 0XFE000
Flash Configuration
BAUD RATE : 115200 (Tried with 9600 baud also)
FLASH SIZE : 8MB
FLASH SPEED : 40MHz
SPI : DIO (Tried with QIO also)
Trial to recover:
a) Reflash module with NodeMCU 0.9.6 at 0x000  fail, same error
b) Reflash module with following binaries  fail, same error
blank.bin : 0XFE000
c) Power supply problem:
Used external power supply from beaglebone 3.3V and applied 100uF capacitor on rails (between VCC and GND, to avoid any noise )  fail, same error
Terminal output:
CODE: SELECT ALL
load 0x4010f000, len 1264, room 16
tail 0
chksum 0x42
csum 0x42
~ld
epc1=0x402147a4, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
d) Reflash module with latest AT firmware found on github
blank.bin : 0XFE000
No more fatal exception, just that module goes into reset automatically.
Esplorer not able to detect
AT firmware installed properly and AT is working fine.
Postby pratik » Fri Jan 13, 2017 2:09 pm
epc1=0x402147a4
This is the address of the instructions that cause exceptions. Does anyone here have the .S file of the output binary that has been causing exceptions? That file is absolutely necessary to get an idea of which function is actually triggering exception.
Random resets are power supply issue most of the time. But seems like something else here, I am not able to reproduce this issue.
Feel free to send me the binary files + your ESP8266 system config info on pratik@espressif.com so that I can check the binaries out. A .S file is much appreciated!
By the way, if you are breadboarding with ESP8266, do watch out for ground loops. A ground loop on a breadboard will mess your system if there are RF components involved.
Users browsing this forum: LanceNic, titshooting and 1 guest
