non-os_sdk_iot_demo can not use curl
Posted: Thu Oct 27, 2016 10:15 am
by sunsiyuan
我使用pc的curl工具向云申请设备的控制权,我的pc是windows的。
curl -X POST -H "Authorization:token798b55d0cd2983dc66e9e82b4b37a906a61543e5"-d "{\"token\":\"55b2bcb6495ded05464b1ea746171b625afb1ca2\"}" http://iot.espressif.cn/v1/key/authorize/
但是回复一直是500的错误。
这是一个什么问题。
Re: non-os_sdk_iot_demo can not use curl
Posted: Thu Aug 10, 2017 11:09 am
by JacksonLv
I have the same problem as you ,seems the token didn't parsed correctly.
Posted: Thu Aug 10, 2017 2:15 pm
by Her Mary
There should be a blank space between the number and "token", as below:
Authorization:token 798b55d0cd2983dc66e9e82b4b37a906a61543e5
