Domain server
Domain server
Postby Clemzo » Sun Feb 12, 2017 5:56 pm
I need to create a domain on my local network.
Do you think is possible to create a ".esp" or ".dom.esp" domain (I prefere the first one) with an ESP8266 ?
Thank for your help.
Re: Domain server
Postby pratik » Wed Mar 01, 2017 2:43 pm
I think using mDNS APIs from the SDKs will be the best option for getting this done.
The other option would be to have this ESP server use a static IP and then add a custom domain name record in your clients such that a specific domain name will always point to the IP of the ESP8266 server.
Re: Domain server
Postby Clemzo » Thu Mar 02, 2017 1:40 am
Thanks for your answer.
I have already used the mDNS, but this solution is multicast and the response times are not satisfactory.
Currently I use serverDNS on ESP and external domain server on my LAN.
It is the good way.
Now I want create a domain server with ESP.
Is it possible ?
