Wrongly reacting to and sending 802.11 beacons with Channel Switch Announcement
st0ff3r
Postby st0ff3r » Thu Jun 04, 2020 7:42 am
ESP's appear to honour 802.11 beacons containing CSA even if they are not connected to the AP sending the beacon.
Here is a simple command that sends out beacons containing CSA's
https://github.com/nabovarme/beacon_spammer
I am using an esp8266 with non-os sdk latest from master git.
The app is here: https://github.com/nabovarme/MeterLogger it is running as an AP and periodically scanning for wireless networks.
This is a severe error in the 802.11 implementation. Both the sending of CSA's and reacting on them while scanning should not happen I guess.
st0ff3r
Re: Wrongly reacting to and sending 802.11 beacons with Channel Switch Announcement
Postby st0ff3r » Mon Dec 28, 2020 7:41 am
Espressif, anyone having time to check it?
Postby ESP_Faye » Tue Dec 29, 2020 11:10 am
So sorry that we missed this topic before. We have arranged an engineer to check with this issue. But due to the isolation caused by COVID-19, it may need some time to check and debug this issue. I will feedback to you as soon as there is any update. Sorry again for the inconvenience.
st0ff3r
Postby st0ff3r » Tue Jan 05, 2021 9:07 am
Cool, thanks a lot :)
Postby Her Mary » Fri Jan 15, 2021 4:10 pm
Does ESP8266 RTOS also have the same issue?
st0ff3r
Postby st0ff3r » Wed Feb 03, 2021 12:39 am
Have not tried
Postby ESP_Faye » Thu Feb 18, 2021 2:24 pm
Hi st0ff3r,
Sorry that we cannot reproduce the issue you reported.
As the picture showed, the captured beacon after scanning does not contain CSA.
Maybe you can try to debug this issue with the attached libnet80211.a, we added some logs into it.
If you can reproduce the issue with this debug lib, could you provide the logs for analyzing?
libnet80211.a.zip
(113 KiB) Downloaded 1148 times
st0ff3r
Postby st0ff3r » Sun Feb 28, 2021 5:50 am
Thank you. I will try it asap :)
st0ff3r
Postby st0ff3r » Sun Feb 28, 2021 8:09 am
just tried it, the log gives the following when scanning and then looses internet connectivity and wifi_station_scan-callback handler returns either 1 or 4 (showed in the log as the second parameter to "-> wifi_scan_done_cb(...)"
"-> wifi_scan_timer_func()" is starting the scan by calling wifi_station_scan()
MQTT: received MQTT_MSG_TYPE_PUBCOMP for id: 6
-> MQTT_Task()
event sig: 0, par: 1073685192, conn state: 17
-> MQTT_Task()
TCP: data received 102 bytes
topic_len: 34, data_len: 64
-> MQTT_Task()
RSSI: -61
@@ set csa state to CSA start 2
@@ add csa 3
@@ add csa 1
@@ add csa 3
@@ add csa 1
@@ add csa 3
@@ add csa 1
@@ add csa 3
@@ add csa 1
@@ add csa 1
switch to channel 2
scandone
-> wifi_scan_done_cb(3fff7500, 1)
-> wifi_start_scan(WIFI_SCAN_INTERVAL)
@@ set csa state to CSA done
RSSI: -61
@@ add csa 3
@@ add csa 1
@@ add csa 3
@@ add csa 1
@@ add csa 3
@@ add csa 1
switch to channel 2
scandone
RSSI: -63
@@ add csa 3
@@ add csa 1
switch to channel 2
scandone
RSSI: -63
@@ add csa 3
@@ add csa 1
@@ add csa 3
@@ add csa 1
@@ add csa 3
@@ add csa 1
switch to channel 2
scandone
RSSI: -63
@@ add csa 3
@@ add csa 1
switch to channel 2
scandone
-> MQTT_Task()
event sig: 0, par: 1073685192, conn state: 18
MQTT: Send keepalive packet to mqtt-host:1883!
MQTT: Sending, type: 12, id: 0000
-> MQTT_Task()
RSSI: -63
@@ add csa 3
@@ add csa 1
@@ add csa 3
@@ add csa 1
@@ add csa 3
@@ add csa 1
@@ add csa 3
@@ add csa 1
switch to channel 2
scandone
-> wifi_scan_done_cb(3fff7a10, 4)
scandone
RSSI: -64
@@ add csa 3
@@ add csa 1
switch to channel 2
scandone
-> wifi_scan_done_cb(3fff4338, 1)
RSSI: -64
@@ add csa 3
@@ add csa 1
@@ add csa 3
@@ add csa 1
switch to channel 2
scandone
-> wifi_scan_done_cb(3fff4338, 4)
scandone
RSSI: -64
@@ add csa 3
@@ add csa 1
@@ add csa 1
@@ add csa 3
@@ add csa 1
@@ add csa 1
@@ add csa 3
@@ add csa 1
switch to channel 2
scandone
RSSI: -63
@@ add csa 3
@@ add csa 1
@@ add csa 1
@@ add csa 3
@@ add csa 1
switch to channel 2
scandone
scandone
MQTT: queuing publish, length: 196, queue size(0/12288)
€?5é -> MQTT_Task()
MQTT: Sending, type: 3, id: 0007
MQTT: espconn_send() returned an error, re-queueing
RSSI: -63
@@ add csa 3
@@ add csa 1
switch to channel 2
scandone
RSSI: -63
@@ add csa 3
@@ add csa 1
@@ add csa 3
@@ add csa 1
switch to channel 2
scandone
scandone
RSSI: -63
@@ add csa 1
@@ add csa 3
@@ add csa 1
@@ add csa 3
@@ add csa 1
switch to channel 2
scandone
RSSI: -63
@@ add csa 3
@@ add csa 1
@@ add csa 1
@@ add csa 3
@@ add csa 1
@@ add csa 1
@@ add csa 3
@@ add csa 1
@@ add csa 3
@@ add csa 1
@@ add csa 1
switch to channel 2
scandone
RSSI: -63
@@ add csa 3
@@ add csa 1
switch to channel 2
scandone
RSSI: -62
@@ add csa 3
@@ add csa 1
switch to channel 2
scandone
-> MQTT_Task()
-> MQTT_Task()
event sig: 0, par: 1073685192, conn state: 7
TCP: Disconnected callback
mqtt_disconnected_cb
TCP: Free memory
TCP: Connect to domain mqtt-host:1883
dns_gethostbyname() returned ERR_OK
-> mqtt_dns_found()
DNS: found ip 193.89.248.25
TCP: connecting...
-> MQTT_Task()
event sig: 0, par: 1073685192, conn state: 10
-> MQTT_Task()
RSSI: -62
@@ add csa 3
@@ add csa 1
switch to channel 2
scandone
-> wifi_scan_done_cb(3fff75c0, 1)
mqtt_timeout_cb
-> MQTT_Task()
event sig: 0, par: 1073685192, conn state: 9
TCP: Free memory
-> mqtt_dns_found()
TCP: connecting...
TCP: Reconnect to: mqtt-host:1883
TCP: Reconnect to mqtt-host:1883
-> MQTT_Task()
event sig: 0, par: 1073685192, conn state: 8
-> MQTT_Task()
RSSI: -62
@@ add csa 1
@@ add csa 3
@@ add csa 1
switch to channel 2
scandone
-> wifi_scan_done_cb(3fff43b8, 1)
mqtt_timeout_cb
-> MQTT_Task()
TCP: Free memory
-> mqtt_dns_found()
TCP: connecting...
-> MQTT_Task()
RSSI: -62
@@ add csa 3
@@ add csa 1
@@ add csa 1
@@ add csa 1
@@ add csa 3
@@ add csa 1
@@ add csa 1
@@ add csa 3
@@ add csa 1
switch to channel 2
scandone
mqtt_timeout_cb
-> MQTT_Task()
TCP: Free memory
-> mqtt_dns_found()
TCP: connecting...
-> MQTT_Task()
-> MQTT_Task()
RSSI: -66
@@ add csa 3
@@ add csa 1
switch to channel 2
scandone
mqtt_timeout_cb
-> MQTT_Task()
TCP: Free memory
-> mqtt_dns_found()
TCP: connecting...
-> MQTT_Task()
Postby ESP_Faye » Thu Mar 04, 2021 10:04 am
Could you have a try that change `wifi_station_set_reconnect_policy(1);` to `wifi_station_set_reconnect_policy(0);`, to see if the issue persists?
https://github.com/nabovarme/MeterLogge ... in.c#L1188
