Bug in FW ESP8266_NO_OS_KRAK
Posted: Fri Nov 24, 2017 10:28 pm
by edison_cz
Dear community,
recently I upgraded to KRAK patch (AT version:1.5.0.0(Oct 24 2017 12:03:18)
SDK version:2.1.0(ace2d95)
compile time:Oct 24 2017 15:48:02
Bin version(Wroom 02):1.5.1)
and have issue with server mode and IE11. The (shortened) sequence follows:
> AT+CWJAP
> AT+CIPSERVER=1,80
< 0,CONNECT
< +IPD: xxx
> AT+CIPSENDBUF=0,2048 ...
< 0,SEND OK
< 0,SEND OK
< 0,SEND OK
< 0,CLOSED
The following connection proceeds with error:
< 0,CONNECT
< +IPD: xxx
< 1,CONNECT
< +IPD: xxx
and very quickly follows
< 0:CONNECT FAIL
< 1:CONNECT FAIL
< 0:CONNECT
< 1:CONNECT
several times. After some time (seconds, far below timeout), the 0,CONNECT reports successful connection, but
never confirms reception ready with '>'.
Even if the connection times out after 30 seconds and IE11 requests another packet, the AT+CIPSENDBUF doesn't get the ESP '>' response.
In Chrome, where the x,CONNECT FAIL doesn't happen, the multi-threaded server responds correctly.
So, my 2 questions: what x,CONNECT FAIL means in server mode and why ESP8266 stops listening to AT commands (at least to AT+CIPSENDBUF)?
Thank you!
Tomas
Re: Bug in FW ESP8266_NO_OS_KRAK
Posted: Wed Nov 29, 2017 10:32 am
by ESP_Faye
x,CONNECT FAIL means the connection fail to be established.
Could you provide the entire test steps so that we can test it exactly as your way to reproduce your problem?
And could you capture the packets by wireshark for debugging?
