[Resolved]None of the flashing bins work. Are there any suggestions?
asperks
Postby asperks » Thu Sep 10, 2015 11:07 am
I'm using the firmware downloaded from here :
viewtopic.php?f=46&t=919&p=3092
I've followed the readme directions in the documentation (below), put in the flashing parameters into the flashing download tool (attached screen cap) and it flashes the ESP.
When I connect via putty, there's no response to any comms(attached screen cap). I can type, but no response. This happens with every different espressif firmware I've found.
When i disconnect power and re-connect, i get garbage, then a 'ready', and the same non-responsive window.
What am I doing wrong? I can't get any of these firmwares to work?
readme.txt in documentation :
download:
boot_v1.2+.bin 0x00000
user1.1024.new.2.bin 0x01000
blank.bin 0x7e000 & 0xfe000
or
eagle.flash.bin 0x00000
eagle.irom0text.bin 0x40000
*NOTICE*:
1.If you use Esp Flash Download Tool, please MAKE SURE to choose FLASH SIZE to 8Mbit.
2.UPDATE is not supported in non-boot mode
Re: None of the flashing bins work. Are there any suggestions?
Postby ESP_Faye » Thu Sep 10, 2015 5:52 pm
According to the "ready" from your UART output, it seems that your AT firmware runs well.
Please notice that AT command is ended with \r\n (CR LF), a new line.
Or you can use SecureCRT as UART tool, and set it to be "new line mode".
asperks
Postby asperks » Wed Sep 16, 2015 8:43 pm
Thankyou, that was exactly the problem. Putty wasn't able to provide the correct line feeds. SecureCRT, with a little bit of play (i.e. Edit/Reset) allowed me to use a terminal to access the AT functionality.
Thanks very much.
jgustavoam
Re: [Resolved]None of the flashing bins work. Are there any suggestions?
Postby jgustavoam » Tue Nov 10, 2015 4:06 am
You can use another Serial Terminal emulator for Windows:
Termite version 3.2 - complete setup
http://www.compuphase.com/software_termite.htm
Configure those parameters, and select your COM port.
Users browsing this forum: No registered users and 26 guests
