Meaning of ICACHE_FLASH_ATTR
Re: Meaning of ICACHE_FLASH_ATTR
Postby eriksl » Sat Oct 03, 2015 3:00 pm
Postby mariuszb » Thu Dec 10, 2015 9:49 pm
1. With ICACHE_FLASH_ATTR progam is located in FLASH, and if necessary read directly from FLASH, or before use sent to a cache? and than used ?
2. Without ICACHE_FLASH_ATTR program is loaded into IRAM at start, and if there is no place for all ?
The rest is located in Flash is run directly from FLASH or with cache ?
Best Regards
Mariusz
Postby eriksl » Fri Dec 11, 2015 3:22 am
code without ICACHE_FLASH_ATTR will end up in irom (flash) and will be copied to iram (ram) on bootup.
The iram space is quite limited, including space needed by SDK and other libraries you will only have a few kbytes for your own application. So add the phrase to every function you declare.
Postby philip » Tue Feb 09, 2016 11:28 am
If there is a cache, how big is it?
I'm trying to figure out how the performance of the internal instruction ram and external flash differ -- so I can allocate code correctly.
Postby eriksl » Tue Feb 09, 2016 4:33 pm
But I can answer your last question: simply put ALL your code in flash (apart maybe from a few a very small functions that handle interrupts). The libs from the SDK already take up most of the IRAM so you will run out of it very quickly.
electronicsguy
Postby electronicsguy » Mon Apr 25, 2016 3:31 am
eriksl wrote:Very good questions, this has been all mysterious.
If we program using Arduino IDE, do we have control over where we can put our code, if we want?
Postby NiclasH » Thu May 26, 2016 6:22 pm
#define ICACHE_FLASH_ATTR
i.e. nothing!!!!
And that definition doesn't match dkinzer's (probably) pasted code from c_types.h back at that time.
SO, I ran a test, just to make sure. And yes, this macro has no meaning in my SDK (ESP8266_RTOS_SDK_V1.4.0/), exactly the same binaries are produced no matter if I add or remove it.
The definition now is;
#define __packed __attribute__((packed))
#define STORE_ATTR __attribute__((aligned(4)))
#define SHMEM_ATTR
#define DMEM_ATTR __attribute__((section(".bss")))
#define IRAM_ATTR __attribute__((section(".text")))
#define ICACHE_RODATA_ATTR __attribute__((section(".irom.text")))
So, I guess that for stuff that I really need in IRAM (interrupt routines and Flash FS), should be marked with the IRAM_ATTR macro, and data that is totally constant could be marked with ICACHE_RODATA_ATTR.
Is there anyone that can confirm this?
Cheers
Niclas
Postby pratik » Sat Jul 09, 2016 10:09 pm
NiclasH wrote:Very interesting thread. I got here because I wanted to find out what does this ICACHE_FLASH_ATTR means, and to my surprise the c_types.h showed;Code: Select all
i.e. nothing!!!!
The definition now is;Code: Select all
#define SHMEM_ATTR
Cheers
Niclas
Hello Niclas,
As mentioned in the SDK getting started guide, all functions are stored in CACHE area by default since ESP8266_RTOS_SDK_v1.2.0.
You need not add the attribute anymore to every function.
And you are correct about IRAM and RODATA part.
Postby pratik » Sat Jul 09, 2016 10:16 pm
mkeyno wrote:what is the benefits to put the function in different type of memory , if is due to speed how much each section has different
The speed difference might not be much if you are running your code off 80MHz QIO flash. Typically, assuming ideal conditions, you may have a 15-20% code execution speed increase by using IRAM instead of CACHE.
However, if you share the primary flash SPI interface to drive IO expanders or communication chips, you should run code from IRAM when the code cannot fit in the cache. That can make a big difference at times.
Do note that the LOADING SPEED and EXECUTION SPEED are two completely different things. Running a huge inline routine with no loops from IRAM will not be much faster than CACHE mode.
However, for applications like ciphers or other complex looping code, IRAM will prove way better than the CACHE. The loading time is the same - only execution times make the big difference.
Hope that helps!
Users browsing this forum: No registered users and 311 guests
