[Resolved]Is there an AT command to turn OFF automatic re-connection?
asperks
Postby asperks » Mon Oct 05, 2015 9:01 am
I use the latest espressif AT firmware.
I have a mesh network of ESP devices, but I can't figure out how to turn off automatic connections to an access point. When I use my ESP device to connect to another ESP device, and I cancel the connection, it automatically attempts to re-connect. If the previous device is on, it will connect to the AP. I imagine its a very helpful feature for some.
Is there a way to turn this off? I want to be able to connect, disconnect, and then stay disconnected to an access point.
Re: Is there an AT command to turn OFF automatic re-connection?
Postby ESP_Faye » Thu Oct 08, 2015 5:19 pm
You could try command "AT+CWAUTOCONN=0" to disable the auto-connect.
asperks
Postby asperks » Thu Oct 08, 2015 9:05 pm
Thanks. Fixed the problem.
Your support rocks.
Users browsing this forum: No registered users and 27 guests
