Problems running softAP -SDK 1.4.0 [SOLVED]
pcbass
Re: Problems running softAP -SDK 1.4.0 [SOLVED]
Postby pcbass » Tue Oct 27, 2015 10:20 pm
I also use SDK 1.4.0 and have the same UART message as below.
chg_A3:0
chg_A3:-180
chg_A3:0
chg_A3:-180
Could anyone know how to fix it ?
yaoyonnghuan
Postby yaoyonnghuan » Thu Nov 05, 2015 2:28 pm
Hi , I also have same problem, i download the new"esp_iot_sdk_v1.4.1_pre5_15_10_27" SDK ,but the problem is still on, i can't find any AP .How to fixt it?
This is the source code :
void user_init(void)
UART_SetBaudrate(UART0,115200); //只能使用本函数设置
wifi_set_opmode(SOFTAP_MODE);
struct softap_config config;
wifi_softap_get_config(&config); // Get soft-AP config first.
os_memset(config.ssid, 0, 32);
os_memset(config.password, 0, 64);
os_memcpy(config.ssid, "ESP8266", 7);
os_memcpy(config.password, "12345678", 8);
config.authmode = AUTH_WPA2_PSK;
config.ssid_len = 0; // or its actual SSID length
config.ssid_hidden = 0;
config.max_connection = 4;
config.channel = 1;
config.beacon_interval=100;
wifi_softap_set_config(&config); // Set ESP8266 soft-AP config
os_free(&config);
This is download setting: bank.bin---> 0x7e000 bank.bin--> 0x3fe000 esp_init_data_default.bin--> 0x3fc000 eagle.flash.bin-->0x00000 eagle.irom0text.bin-->0x40000
The log information: ( I send out the version infomation every 3 seconds)
ets Jan 8 2013,rst cause:1, boot mode:(3,1)
load 0x40100000, len 27488, room 16
tail 0
chksum 0x38
load 0x3ffe8000, len 884, room 8
tail 12
chksum 0xc5
ho 0 tail 12 room 4
load 0x3ffe8380, len 276, room 12
tail 8
chksum 0x51
csum 0x51
rS3ffffa70 already freed
mode : softAP(1a:fe:34:a2:b9:4f)
add if1
bcn 100
SDK version:1.4.1(pre2)
chg_A3:-180
chg_A3:0
chg_A3:-180
Postby ESP_Faye » Mon Nov 09, 2015 2:19 pm
Please have a try with the attachment.
lib_1.4.1_pre7.zip
(806.63 KiB) Downloaded 279 times
BarryP
Postby BarryP » Sat Nov 14, 2015 10:31 am
FYI .
I was having the same Problem & The Updated Libs ( lib_1.4.1_pre7.zip) Fixed It .
tve
Postby tve » Wed Nov 18, 2015 1:24 pm
@Espressif_Faye can you please provide liblwip_536.a for SDK v1.4.1_pre7 ?
Thanks!
lobaro
Postby lobaro » Wed Dec 02, 2015 2:03 am
is this Patch also included into SDK1.5?
We have no problems using 1.41 but with 1.5 often clients can't connect to the softAP...
lea.z
Postby lea.z » Fri Dec 25, 2015 2:55 pm
lobaro wrote:is this Patch also included into SDK1.5?
just connecting…… my phone cannot connect to my model that configured as softAP. And you got?
eswarams
Postby eswarams » Sat Apr 02, 2016 2:59 pm
Hi Is the same fix applicable for RTOS 1.4.0 . I face similar issue where station does not get IP when ESP is in AP mode. Also socket open fails.
