Problems running softAP -SDK 1.4.0 [SOLVED]
yaoyonnghuan
Re: Problems running softAP -SDK 1.4.0 [SOLVED]
Postby yaoyonnghuan » Thu Nov 05, 2015 2:28 pm
Hi , I also have same problem, i download the new"esp_iot_sdk_v1.4.1_pre5_15_10_27" SDK ,but the problem is still on, i can't find any AP .How to fixt it?
This is the source code :
void user_init(void)
UART_SetBaudrate(UART0,115200); //只能使用本函数设置
wifi_set_opmode(SOFTAP_MODE);
struct softap_config config;
wifi_softap_get_config(&config); // Get soft-AP config first.
os_memset(config.ssid, 0, 32);
os_memset(config.password, 0, 64);
os_memcpy(config.ssid, "ESP8266", 7);
os_memcpy(config.password, "12345678", 8);
config.authmode = AUTH_WPA2_PSK;
config.ssid_len = 0; // or its actual SSID length
config.ssid_hidden = 0;
config.max_connection = 4;
config.channel = 1;
config.beacon_interval=100;
wifi_softap_set_config(&config); // Set ESP8266 soft-AP config
os_free(&config);
This is download setting: bank.bin---> 0x7e000 bank.bin--> 0x3fe000 esp_init_data_default.bin--> 0x3fc000 eagle.flash.bin-->0x00000 eagle.irom0text.bin-->0x40000
The log information: ( I send out the version infomation every 3 seconds)
ets Jan 8 2013,rst cause:1, boot mode:(3,1)
load 0x40100000, len 27488, room 16
tail 0
chksum 0x38
load 0x3ffe8000, len 884, room 8
tail 12
chksum 0xc5
ho 0 tail 12 room 4
load 0x3ffe8380, len 276, room 12
tail 8
chksum 0x51
csum 0x51
rS3ffffa70 already freed
mode : softAP(1a:fe:34:a2:b9:4f)
add if1
bcn 100
SDK version:1.4.1(pre2)
chg_A3:-180
chg_A3:0
chg_A3:-180
config.channel = 1;
os_free(&config);
tail 0
chksum 0x38
tail 12
chksum 0xc5
ho 0 tail 12 room 4
tail 8
chksum 0x51
csum 0x51
add if1
bcn 100
chg_A3:-180
chg_A3:0
chg_A3:-180
Postby ESP_Faye » Mon Nov 09, 2015 2:19 pm
Please have a try with the attachment.
- Attachments
- lib_1.4.1_pre7.zip
- (806.63 KiB) Downloaded 587 times
Postby lea.z » Fri Dec 25, 2015 2:55 pm
lobaro wrote:is this Patch also included into SDK1.5?
We have no problems using 1.41 but with 1.5 often clients can't connect to the softAP...
just connecting…… my phone cannot connect to my model that configured as softAP. And you got?
Users browsing this forum: No registered users and 140 guests
