ESP8266 UART overrun in RTS/CTS
wjzhang
Postby wjzhang » Tue Dec 08, 2015 12:28 pm
Hi, i found my uart get Overrun error when the RTS/CTS enable, it cause lost data on uart. i set RTS rise when FIFO reach to 120(0x78).
if((pconfig->hwflowctrl == USART_HardwareFlowControl_CTS_RTS) || (pconfig->hwflowctrl == USART_HardwareFlowControl_RTS))
SET_PERI_REG_MASK(UART_CONF1(uart_no), ((0x78 & UART_RX_FLOW_THRHD) << UART_RX_FLOW_THRHD_S) | UART_RX_FLOW_EN );
question:
1) why the overrun happened when RTS enable? :o
2) when the RTS fall? the Rx FIFO data all read? or Rx FIFO data less than threshold?
the client follow the RTS/CTS.
wjzhang
Re: ESP8266 UART overrun in RTS/CTS
Postby wjzhang » Tue Dec 08, 2015 3:07 pm
sorry for missing test environment:
ESP8266 SDK: NoOS SDK 1.5.0.
Client: using RTS/CTS handshake, block only the ESP8266 RTS is high.
the RX full threshold is 3/4 FIFO= 96bytes=0x60.
//set rx 3/4 FIFO trigger, 2 byte time out
WRITE_PERI_REG(UART_CONF1(uart_no),
((0x60 & UART_RXFIFO_FULL_THRHD) << UART_RXFIFO_FULL_THRHD_S) |
(0x02 & UART_RX_TOUT_THRHD) << UART_RX_TOUT_THRHD_S | UART_RX_TOUT_EN );
wjzhang
Postby wjzhang » Thu Dec 10, 2015 11:01 am
sorry, my fault. ESP8266 work fine, one is hardware fault(STM32F013). another is Software fault(STM32F405). :(
But i still need answer for second question. Could somebody tell me? Thanks!
Postby ESP_Faye » Fri Dec 11, 2015 10:18 am
We have tested it, here is the test result :
The flow control is set to be 110 bytes,
if there are more than 110 (>110) bytes in RX FIFO, RTS is in high-level.
if there are less than 110 (<=110) bytes in RX FIFO, RTS is in low-level.
Users browsing this forum: Baidu [Spider] and 7 guests
