GPIO16 and setting RST line
geo.espressif
Postby geo.espressif » Mon Dec 14, 2015 5:11 pm
Could anyone help me with some code to set GPIO16 low, it appears to be interfering with our ability to reset the device (it's causing a fight over reset line being low/high). There don't seem to be any register definitions for it in eagle_soc.h
James
dkinzer
Re: GPIO16 and setting RST line
Postby dkinzer » Wed Dec 16, 2015 11:51 pm
geo.espressif wrote:Could anyone help me with some code to set GPIO16 low
For future reference, the Arduino-ESP8266 code is a good place to begin researching how to accomplish something on the ESP8266.
To use GPIO16, you must map it to be an I/O pin somewhere in your initialization:
uint32_t val;
// map GPIO16 as an I/O pin
val = READ_PERI_REG(PAD_XPD_DCDC_CONF) & 0xffffffbc;
WRITE_PERI_REG(PAD_XPD_DCDC_CONF, val | 0x00000001);
val = READ_PERI_REG(RTC_GPIO_CONF) & 0xfffffffe;
WRITE_PERI_REG(RTC_GPIO_CONF, val | 0x00000000);
Then, to set GPIO16 high or low:
// set the pin state first, then enable output
val = READ_PERI_REG(RTC_GPIO_OUT);
WRITE_PERI_REG(RTC_GPIO_OUT, pinHigh ? (val | 1) : (val & ~1));
val = READ_PERI_REG(RTC_GPIO_ENABLE);
WRITE_PERI_REG(RTC_GPIO_ENABLE, val | 1);
For completeness, this is how you read GPIO16 as an input:
// set as an input
WRITE_PERI_REG(RTC_GPIO_ENABLE, val & ~1);
// read the input state
val = READ_PERI_REG(RTC_GPIO_IN_DATA) & 1);
Don Kinzer
Beaverton, OR, USA
geo.espressif
Postby geo.espressif » Wed Feb 03, 2016 5:40 pm
Awesome, thanks!
fengwanjun
Postby fengwanjun » Sat Mar 19, 2016 10:36 pm
I use your code .
But like the old ones. When gpio16_output_set(0),it goes like a system reset.
Why????
