New 2.0 NONOS SDK not working
simonliu
Re: New 2.0 NONOS SDK not working
Postby simonliu » Sun Sep 18, 2016 2:55 pm
I got the following error
DEPEND: xtensa-lx106-elf-gcc -M -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -fno-builtin-printf -DICACHE_FLASH -I include -I ./ -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle -I ../../driver_lib/include user_main.c
/bin/sh: xtensa-lx106-elf-gcc: command not found
xtensa-lx106-elf-gcc -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -fno-builtin-printf  -DICACHE_FLASH   -I include -I ./ -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle -I ../../driver_lib/include  -o .output/eagle/debug/obj/user_main.o -c user_main.c
make[1]: xtensa-lx106-elf-gcc: No such file or directory
make[1]: *** [.output/eagle/debug/obj/user_main.o] Error 1
make: *** [.subdirs] Error 2
Postby pratik » Mon Sep 19, 2016 11:11 am
Your toolchain is not configured or maybe not installed at all!
You should get this when you open the terminal and enter
xtensa-lx106-elf-gcc -v
Expected output:
Note that the GCC version should be printed as in the screenshot. If you get a "command not recognized" or something like that - you have a toolchain problem!
simonliu
Postby simonliu » Tue Sep 20, 2016 10:06 pm
Thank you. I was using a self-extracted IDE from Ai-thinker ( a esp8266 module vendor). Anyway , I finally managed to compile the smart config in the windows IDE. I decide to forget about the command line tool cause I have no idea how to set up the toolchain. :D
Postby pratik » Wed Sep 21, 2016 10:55 am
Just in case you did not know, or for other people who are reading this post, you may read the Getting Started guide for ESP8266, where there is a Virtual Machine image link available. The image has Linux OS with ESP8266 toolchain configured already and it will take up like 5 minutes to get things up and running there. :)
Windows is cool as well though!
