WPS (Wi-Fi Protected Setup) in SDK
russus
Re: WPS (Wi-Fi Protected Setup) in SDK
Postby russus » Tue Nov 29, 2016 1:45 am
gjump,
I can't express enough how much I appreciate your time and efforts in explaining this. It became crystal clear and finally worked :) !!!
I thought of the role of key_init_single(...) in a very wrong way. It seemed to me that it somehow emulates a physical push.
Well, I am very new to this stuff. I hope you can forgive me ;)
gjump
Postby gjump » Tue Nov 29, 2016 1:56 am
Russus, no problem at all, we are here to help and get helped.
Can you provide the model of your router? And the encryption used(WPA, WPA2, TKIP/AES...).
-Sheers
russus
Postby russus » Tue Nov 29, 2016 2:23 pm
Asus rt-ac51u Dual Band. Encryption - WPA2(AES)
My next step now is to try triggering WPS from my main microcontroller which is connected to ESP.
dalbert
Postby dalbert » Sat Jul 22, 2017 8:01 pm
I have been able to establish connections via WPS successfully to several types of 802.11n access points but connections fail to 802.11ac access points; has anyone else had this problem?
dalbert
Postby dalbert » Sat Jul 22, 2017 8:58 pm
Access Points tested and working with ESP8266 WPS: Trendnet TEW-652, Belkin N300
Access Points tested and failing with ESP8266 WPS: AT&T/Pace 5268AC and Asus TM-AC1900
(tested with SDK version: 1.5.3(aec24ac9)
dalbert
Postby dalbert » Sat Sep 23, 2017 5:29 pm
Part of the problem turns out to be free RAM. The 802.11ac WPS process requires considerably more free RAM than for 802.11a/b/g/n. My application had some large statically allocated tables. When I changed these to be dynamically allocated after WPS completed, it worked properly for some access points. It still fails for many others. tested with SDK 1.5.3 and 2.1.0.
