Q: os_sprintf.. : Float / Double
rudi
Postby rudi » Fri Nov 14, 2014 3:33 am
hi guys
i play with float and double
char temp[100];
os_sprintf(temp, " Where is my Float : %f \r", 12.34);
os_sprintf(temp, " Where is my Float : %2.2f \r", 12.34);
os_sprintf(temp, " Where is my Float : %.2f \r", 12.34);
get not the right formated string.
a try with %e and %E
os_sprintf(temp, " Where is my Float : %e \r", 12.34);
os_sprintf(temp, " Where is my Float : %E \r", 12.34);
same.
how you format floats ;-) 12.34 ?
thank you!
best wishes
rudi ;-)
問候飛出去的朋友遍全球魯迪
vishnu046
Re: Q: os_sprintf.. : Float / Double
Postby vishnu046 » Mon Nov 17, 2014 6:39 pm
Hi rudy,
OS_SPRINTF doesnt supprot %f ...
i am using like this...
iftoa.rar
to print float
(817 Bytes) Downloaded 1256 times
Vishnu
rudi
Postby rudi » Mon Nov 17, 2014 7:46 pm
vishnu046 wrote:Hi rudy,
hi vishnu ;-)
thank you so much for your effort and help.
i will test asap ;-) i search in
http://www.cs.fsu.edu/~baker/devices/lx ... t/printf.c
for making a function .. without boot.h ..
so you have save me the work
thank you!!
best wishes rudi ;-)
btw: i help me in past like this way, this is a simple way in first step to get decimals..
char temp[100];
char arraystring[5];
float adjustvalue = 1.5;   // my LM35 was difference 1.5 kelvin to the mechanical thermometer to much .. so i substrakt this from measuring value later..
float adc_value;
int decimal, whole;
adc_value = adc_read();
adc_value = ((adc_value * 1000 / 1024 / 9.31 ) - adjustvalue );
whole    = adc_value;
decimal = ( adc_value - whole ) * 10 ; // only deci ..
os_sprintf(arraystr, "%2d.%i", whole, decimal );  // look like 17.5
os_sprintf(temp,"Temp measuring was: %s °C", arraystr);
uart0_sendStr(temp);
or simple without the arraystr..
os_sprintf(temp,"Temp measuring was: %2d.%i °C", whole, decimal);
btw with esp-01 the adc measuring will be fine too, i attached the mod at a esp-01
add a LM35 to the adc pin and get the measuring too ;-)
i love espressif!!!
rudi ;-)
info for negative celsius..
my measuring is allways in + Celsius so i can work this in paste way.. but
if measuring value goes - Celsius, the formated value is
-10.-3 °C
so must change the negative decimal .. i will test yours ;-) thank you!!!
edit'S: misspelling ..name
問候飛出去的朋友遍全球魯迪
Users browsing this forum: No registered users and 213 guests
