Hostname (standard PC-192-168-xxx-xxx)
Re: Hostname (standard PC-192-168-xxx-xxx)
Postby blubb » Wed Jul 01, 2015 5:51 pm
Postby blubb » Thu Aug 13, 2015 11:32 pm
Postby kolban » Fri Aug 14, 2015 1:58 am
Postby ESP_Faye » Fri Aug 14, 2015 4:18 pm
So sorry for the inconvenience. I checked it with our engineer again, esp_iot_sdk_v1.3.0 did not add this optimization.
Here is a patch based on esp_iot_sdk_v1.3.0 to support this new feature.
Please replace it in folder "lib" and add definition below in espconn.h
void espconn_nbns_init(void)Call it after ESP8266 station connected to AP and got a IP address. For example,
wifi_station_set_hostname("esp8266");
espconn_nbns_init();
- Attachments
- liblwip.a.zip
- (102.74 KiB) Downloaded 385 times
Postby blubb » Fri Aug 14, 2015 6:17 pm
When I ping the ESP by host name, Windows tries to ping IP 168.0.135.0 which is not correct. The correct IP would be 192.168.0.135 in my case.
Looking at the IPs I think it was shifted by 1 byte accidentally! So this should be easy to fix if you look at your code.
Postby blubb » Sun Aug 16, 2015 10:00 pm
- Do I need to call it every time ESP8266 got an IP?
- Do I need to call it every time I change the host name with wifi_station_set_hostname?
- Or is it enough calling it only once (in user_init() maybe)?
