I can't connect to the WiFi of the hidden 12-14 channel
LIllac
Postby LIllac » Tue Apr 28, 2020 1:13 pm
I use wifi_station_set_config(struct station_config *config) to write SSID and password directly to config. But I can't connect to the WiFi of the hidden 12-14 channel. If I set the channel to 11, I can connect.
If so, how can I set up WiFi to connect hidden 12-14 channels?
Re: I can't connect to the WiFi of the hidden 12-14 channel
Postby Her Mary » Wed Apr 29, 2020 10:30 am
Maybe due to the Wi-Fi country code. There is a blog, but it is in Chinese. https://blog.csdn.net/espressif/article ... s/78673702
LIllac
Postby LIllac » Thu May 07, 2020 10:19 am
Her Mary wrote:Maybe due to the Wi-Fi country code. There is a blog, but it is in Chinese. https://blog.csdn.net/espressif/article ... s/78673702
I didn't find the wifi_set_country interface in the sdk2.0 of esp8266, but I found the structure of wifi_country_t. What should I do?
Postby Her Mary » Mon May 11, 2020 10:51 am
Maybe you can have a try with the latest 8266 RTOS SDK?https://github.com/espressif/ESP8266_RTOS_SDK
Users browsing this forum: Baidu [Spider] and 7 guests
