I have been playing around with new libmbedtls.a library downloaded from espressif SDK (precompiled from herehttp://espressif.com/sites/default/ ... 160718.zip ) .
It seems there is an issue running IOT Demo HTTP server SSL enabled using mbedTls library. Once I start a client connection this is what happens
=== System init ====
mode : softAP(62:01:94:84:0d:2e)
add if1
bcn 100
add 1
aid 1
station: 90:61:0c:32:59:29 join, AID = 1
server handshake start.
server handshake ok!
server's data invalid protocol
Reason:[-0x7880]
webserver's 192.168.4.33:13907 err 8 reconnect
Fatal exception 28(LoadProhibitedCause):
ÿpc1=0x40001b7f, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000004, depc=0x00000000
ets Jan 8 2013,rst cause:1, boot mode:(3,7)
tail 0
chksum 0xf3
tail 4
chksum 0x92
tail 0
chksum 0x22
csum 0x22
SPI Speed : 40MHz
SPI Mode : DOUT
jump to run user1 @ 1000
I have set the SSL settings as follows on the HTTP server
espconn_secure_set_size(ESPCONN_SERVER, 4096);
espconn_secure_set_default_certificate(default_certificate, default_certificate_len);
espconn_secure_set_default_private_key(default_private_key, default_private_key_len);
espconn_secure_accept(&esp_conn);
I have tested by increasing the size of espconn (6*1024), same happens.
Any idea, why it's happening? What am I missing?
