ESP8622 programmer using ESP8266
eriksl
Postby eriksl » Wed Sep 13, 2017 8:23 pm
Has anyone already tried to make an ESP8266 serial programmer using an ESP8266?
Something like ESP8266_1 connects to ESP8266_2 using serial, ESP8266_1 pulls up and down the GPIO_0, GPIO_2 and RST lines of ESP8266 and starts sending the new firmware.
Most of this is not rocket science, but I am too lazy to reverse engineer esptool.py as to what exactly to send, especially the blob of program code that apparentely is sent to to communicate with the outside world.
I thought maybe someone has done this before? Or has already reverse engineered whatever esptool.py sends (and receives)?
YimingLi
Re: ESP8622 programmer using ESP8266
Postby YimingLi » Sat Sep 16, 2017 6:58 pm
There is a tool for 'lazy' engineer:P
One-press burning tools for ESP8266 modules which is very helpful for batch burning. With the burning tool, you only have to have one press on the button of the software to start the burning, and then the burning process will be completed automatically with the help of UART flow control. If you feel interested, you may please get more about it at http://www.ebay.com/itm/282286419729. It is ready with pin connectors for ESP-01, ESP-12 etc. If your module does not have a matched connector here, you may please using 5 flying wires connecting to a connector which is matched with the connector on your module.
eriksl
Postby eriksl » Sat Sep 16, 2017 7:08 pm
The link doesn't give much information. Is this an USB-serial converter (like CP2102) and some connectors added?
What ESP's can fit out of the box? I need ESP01 and ESP201.
YimingLi
Postby YimingLi » Thu Oct 05, 2017 10:57 pm
eriksl wrote:The link doesn't give much information. Is this an USB-serial converter (like CP2102) and some connectors added?
all of ESP-01, ESP-12x, ESP201 serials can fit the burning toolkit :)
Since they are nearly the same as per the programming and uart communication, only expect different pinout of connectors so with different connectors of programming and uart communication.
Actually, even as per the pinouts of programming and uart communication, esp-12 and esp201 serials are the same.
trice001
Postby trice001 » Sat Nov 18, 2017 7:55 pm
Refreshing your PC is critical as it causes your PC to keep running as easily as possible. The updates are patches to the present PC programming projects, and they are there to help enhance and fix bugs, improve includes and to give your PC better security. For instance, both Macintosh and Windows working frameworks are routinely given updates by different makes. These updates can be effectively introduced by the Software Update that is on your working framework. For Mac Users, Click on the symbol Apple, assigned on the upper left corner of your desktop, at that point go to System Preferences, situated down the rundown. When it's clicked, a window for the System Preferences should now fly up.
Thanks& Regards,
Angel anave
Web Design Company Toronto|Toronto Web Development | Web Development Toronto
Users browsing this forum: No registered users and 20 guests
