Login Failed Since Last two days
ankitsohliya
Postby ankitsohliya » Tue Oct 18, 2016 8:03 pm
From last two days, I am not able to logging in to my account from my mobile application. Apart from this, if I try to update datapoint from my application then it send error-500. The same code had been worked for me till then.
milesstone
Re: Login Failed Since Last two days
Postby milesstone » Sat Oct 09, 2021 9:23 pm
ankitsohliya wrote:Hi,
From last two days, I am not able to logging in to my account from my gbwhatsapp apk mobile application. Apart from this, if I try to update datapoint from my application then it send error-500. The same code had been worked for me till then.
I think there some bugs in it which is why you are not able to login in your account via application, I think you have to clear the applications caches and check it again.
Nielson
Postby Nielson » Mon Oct 11, 2021 8:50 pm
No, there is nothing in app you just have to clear it's caches and data in you app setting and then check it again I hope it will solve your issue.
kol909
Postby kol909 » Mon Jan 03, 2022 1:53 pm
From last two days, I am not able to logging in to my account from my mobile application. Apart from this gbwhatsapp, if I try to update datapoint from my application then it send error-500. The same code had been worked for me till then.
Some time when apps server updating datas this issue happens. Simply use VPn and try it. If it dont works then please share your issue with us with Screen shot.
nobita001
Postby nobita001 » Fri Jan 21, 2022 1:08 am
It happens when some thing has gone wrong on the web site's server but the server could not be more specific on what the exact problem is. You can try login in some other time. May be you will not face it again.
nulls clash is all you need.
