Use ESP8266 GPIO to do IR sending and learning, saving one IR chip.
tiqiaa
Postby tiqiaa » Mon Dec 05, 2016 4:56 pm
GPIO solution of IR sending and learning based on ESP8266
1. Application scenarios of solution
When developers want to add IR sending & learning functions in the products made of Wi-Fi module ESP8266, they only need to load the lib file developed by ZaZaRemote to the modules to realize it. They do not need to use any additional IR remote control chip.
Solution value: spare development time, save a remote control chip and its assembling cost, simplify PCB assay and reduce defect rate.
Special value: The solution is connected to the IR code library of ZaZaRemote, the best one in the world. Huawei, TCL, Lenovo and Philips are all using the code library of ZaZaRemote. Containing 30, 0000 different kinds of remote controls, it has been applied globally with 62 million customers are using it. The code library is still keep growing and maintained by ZaZaRemote continually.
Download SDK here: https://developer.tiqiaa.com/
The following video is use the ESP8266 GPIO to do infrared transmission and infrared learning
http://v.youku.com/v_show/id_XMTgyMDI5ODczMg==.html
For detail, please download and read the annex file.
GPIO solution of IR sending &learning based on Wi-Fi module Espressif ESP8266.docx
(392.35 KiB) Downloaded 501 times
Re: Use ESP8266 GPIO to do IR sending and learning, saving one IR chip.
Postby pratik » Mon Dec 12, 2016 12:58 pm
This will be useful for a lot of people trying to do the same. Thanks for posting! :)
Postby AgentSmithers » Thu Dec 14, 2017 12:31 am
tiqiaa wrote:GPIO solution of IR sending and learning based on ESP8266
What IR Listener device do you use to learn any IR Frequency? I think I have a few from a company called vertech or something model TSOP90802 or something close, can't recall off the top of my head but it has a heck of a KHZ range for detecting IR.
