WPA2 "Method private structure allocated failure" with v2.0.0
SpacedOut
Postby SpacedOut » Thu Dec 22, 2016 2:06 pm
I added some of the enterprise functions to the basic_example and linked with wpa2, but I'm getting what sounds like an out of memory error even with this minimal program. This is with ESP8266_NONOS_SDK_V2.0.0_16_08_10, any ideas? I have the same error if I try a PEM client certificate and private key.
wifi_station_set_wpa2_enterprise_auth(true);
wifi_station_set_reconnect_policy(false);
wifi_station_set_enterprise_username((u8*)EAP_USER, os_strlen(EAP_USER));
wifi_station_set_enterprise_password((u8*)EAP_PASSWORD, os_strlen(EAP_PASSWORD));
wifi_station_connect();
heap 46040 wifi status 1
state: 2 -> 0 (0)
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 1
cnt
Full program here.
https://github.com/dfries/source-code-e ... ser_main.c
user_config.h
#define SSID "Your SSID"
#define SSID_PASSWORD "Your Password Here"
#define EAP_USER "eap_username"
#define EAP_PASSWORD "eap_password"
user_main.c
#include "ets_sys.h"
#include "osapi.h"
#include "gpio.h"
#include "os_type.h"
#include "user_config.h"
#include "user_interface.h"
#include <wpa2_enterprise.h>
#define user_procTaskPrio        0
#define user_procTaskQueueLen    1
os_event_t    user_procTaskQueue[user_procTaskQueueLen];
static void loop(os_event_t *events);
static void ICACHE_FLASH_ATTR
print_heap(os_event_t *events)
    int status = wifi_station_get_connect_status();
    os_printf("heap %u wifi status %u\n", system_get_free_heap_size(), status);
    if(status == STATION_IDLE)
        os_printf("idle, try connecting\n");
    static int connect_count;
    if(status == STATION_CONNECTING)
        ++connect_count;
        if(connect_count == 4)
            os_printf("still in connecting, disconnect and try again\n");
            wifi_station_disconnect();
            connect_count = 0;
//Init function
user_init()
    char ssid[32] = SSID;
    char password[64] = SSID_PASSWORD;
    // default appears to be a non-standard 74880 baud
    uart_div_modify(0, UART_CLK_FREQ / 115200);
    //Set station mode
    //Set ap settings
    // skip station config, expect the station is already setup in flash
    #if 0
    #endif
    os_printf("heap %u line %u\n", system_get_free_heap_size(), __LINE__);
    static os_timer_t heap_timer;
    os_timer_disarm(&heap_timer);
    os_timer_setfn(&heap_timer, &print_heap, NULL);
    os_timer_arm(&heap_timer, 3000, 1);
ESP_Xutao
Re: WPA2 "Method private structure allocated failure" with v2.0.0
Postby ESP_Xutao » Tue Jan 24, 2017 4:42 pm
hi
this is what we do a program,you can consult.
wpa.rar
(4.84 MiB) Downloaded 204 times
