SDIO sample code
kwoodbury1
SDIO sample code
Postby kwoodbury1 » Fri Mar 10, 2017 1:52 am
Our application is going to stream data to the ESP8266 using the SDIO interface. Do you have sample code which transmits data over TCP and/or UDP. Thanks! Kerry
Re: SDIO sample code
Postby ESP_Faye » Wed Mar 22, 2017 11:54 am
Can ESP8266_NONOS_SDK/examples/at_sdio help you?
Download ESP8266 SDK
Danfosqcen
SDIO sample code
Postby Danfosqcen » Tue Aug 20, 2019 10:40 pm
The sample that you request is not a sample is big project to program. You not especifies if the treatement is to potabilize, waterwaster procees, or potabilization abaout sea water. I am water potabilization and waterwaster technical, i works to programming waterwaster facilities.
Remontvfdsspb
SDIO sample code
Postby Remontvfdsspb » Thu Sep 05, 2019 4:52 pm
I am looking for a sample Plc code for the following applications:
- Water treatment plant
- Substation Automation
Any body can help me , I am trying to learn about these 2 processes
