Bug in system_adc_read_fast SDK version 2.0.0(656edbf)
honio
Postby honio » Thu Feb 16, 2017 5:39 pm
i was using the ADC API from your SDK version 2.0.0(656edbf) (NONOS).
If i read the documentation and the .h file i see that the argument adc_num in:
void   system_adc_read_fast   (uint16   *adc_addr,   uint16   adc_num,   uint8
adc_clk_div)
is a 16bit unsigned integer. Interestingly it behaves though like a uchar8 parameter. From 1 to 255 the
function works propperly and gives the correct results. Whenever i set the parameter higher than 255 the function
stays in a endless loop and the system restarts with the watchdog.
Could you please check and give a patch for the adc_num limitation of 255?
Re: Bug in system_adc_read_fast SDK version 2.0.0(656edbf)
Postby ESP_Faye » Tue May 09, 2017 9:49 am
Please have a try with the latest ESP8266_NONOS_SDK_V2.1.
