IOT Espressif APK source code released in Github
paritosharya007
Re: IOT Espressif APK source code has released
Postby paritosharya007 » Sat May 23, 2015 1:31 pm
I am new to Android and was try to generate APK using the source from github in Android Studio. The source opened just fine in Studio but when i try to build the project, no APK is generated and all I get in the log is "All file are up-to-date". Am i missing something or there is a different way of generaing apk from this source code?
Paritosh
paritosharya007
Postby paritosharya007 » Sun May 31, 2015 5:04 pm
I was looking through the source of the APK and could not find any mechanism for port forwarding for over the internet communication. Am I missing something or the there is different technique to communicate over internet?
Joanna Hoo
Postby Joanna Hoo » Mon Jun 08, 2015 11:08 am
Please refer to the attachment for IOT_Espressif_APK_v0.9.2.apk, if you want to install it on your mobile Android devices.
Please refer to https://github.com/EspressifApp/IOT-Espressif-Android for the source codes of IOT Espressif APK. Please read the user manual carefully before you start developing.
BTW, ESP-TOUCH source codes for both Android and iOS devices (using RTOS SDK and non-RTOS SDK) are now released on https://github.com/EspressifApp. Please read the README.md carefully before developing.
Thanks for your attention.
IOT_Espressif_APK_v0.9.2.apk.zip
(1.97 MiB) Downloaded 1972 times
xuxiangjun
Postby xuxiangjun » Mon Jun 08, 2015 2:40 pm
paritosharya007 wrote:Hi,
Paritosh
I download the code from github and import it in Android Studio. Then generate the apk successfully.
Could you check whether you have created a correct Key Store?
You can create a Key Store in Android Studio, select Bulid -> Generate Signed APK -> Create new...
