ADC positive offset on 0V
gjump
Postby gjump » Tue Sep 12, 2017 2:10 am
I'm getting a very annoying problem: I have a project using esp12e and on some boards I got wrong ADC readings(using system_adc_read SDK 2.0.0 NONOS), even when I ground the ADC pin I can read a value ~10mV. I tried to change WiFi modes(all of them) but didn't changed significantly.
Any help is appreciated!
Re: ADC positive offset on 0V
Postby ESP_Faye » Tue Sep 12, 2017 2:10 pm
Could you have a try with the latest ESP8266_NONOS_SDK?
gjump
Postby gjump » Tue Sep 12, 2017 11:48 pm
ESP_Faye wrote:Hi,
Going to try that.
gjump
Postby gjump » Wed Sep 13, 2017 3:56 am
ESP_Faye wrote:Hi,
Faye, same problem, same offset. I'll try on more boards, but I got 50% working and 50% with this problem and I'm always checking the voltage at the pin with a calibrated equipment to be sure.
Any thoughts?
gjump
Postby gjump » Thu Sep 14, 2017 9:36 pm
@ESP_Faye
Things i've tried:
Switched the ESPs between boards to to be sure that isn't the circuit, the problem followed the ESPs.
Wrote a simple code using system_adc_read_fast(), wifi off and got the same result, with the ADC pin grounded it reads 10-12 points.
Yesterday I've built 3 more boards, 2 ok and 1 with this offset. I have now 3 with offset and 4 working.
Don't know what's going on;
Jamartox
View first unread post
Postby Jamartox » Fri Sep 15, 2017 5:40 pm
Dont you have the down arrow to the left of the thread title?
gjump
Re: View first unread post
Postby gjump » Fri Sep 15, 2017 7:23 pm
Jamartox wrote:Dont you have the down arrow to the left of the thread title?
Down arrow? I don't think so. What's that for?
gjump
Postby gjump » Tue Sep 19, 2017 11:05 pm
Anything? Our client is asking for answers!
