编译时提示`.text' will not fit in region `iram1_0_seg' 可能是什么原因?
bobo_zhou
Postby bobo_zhou » Mon Jun 29, 2015 7:46 pm
make[1]: Entering directory `/mnt/Share/esp_iot_sdk_v1.1.1/app'
make[2]: Entering directory `/mnt/Share/esp_iot_sdk_v1.1.1/app/user'
DEPEND: xt-xcc -M -Os -g -O2 -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle user_main.c
DEPEND: xt-xcc -M -Os -g -O2 -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle global_unit.c
make[2]: Leaving directory `/mnt/Share/esp_iot_sdk_v1.1.1/app/user'
xt-xcc -Os -g -O2 -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle -o .output/eagle/debug/obj/global_unit.o -c global_unit.c
xt-xcc -Os -g -O2 -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle -o .output/eagle/debug/obj/user_main.o -c user_main.c
xt-ar ru .output/eagle/debug/lib/libuser.a .output/eagle/debug/obj/global_unit.o .output/eagle/debug/obj/user_main.o
make[2]: Entering directory `/mnt/Share/esp_iot_sdk_v1.1.1/app/driver'
make[2]: Leaving directory `/mnt/Share/esp_iot_sdk_v1.1.1/app/driver'
xt-xcc -L../lib -nostdlib -T../ld/eagle.app.v6.ld -Wl,--no-check-sections -u call_user_start -Wl,-static -Wl,--start-group -lc -lgcc -lhal -lphy -lpp -lnet80211 -llwip -lwpa -lmain -ljson -lupgrade -lssl -lpwm -lsmartconfig user/.output/eagle/debug/lib/libuser.a driver/.output/eagle/debug/lib/libdriver.a -Wl,--end-group -o .output/eagle/debug/image/eagle.app.v6.out
/opt/xtensa-lx106-elf/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld: .output/eagle/debug/image/eagle.app.v6.out section `.text' will not fit in region `iram1_0_seg'
vowstar
Re: 编译时提示`.text' will not fit in region `iram1_0_seg' 可能是什么原因?
Postby vowstar » Tue Sep 27, 2016 11:09 am
上面的回答答非所问,不知道误导了多少人
在所有非中断函数之前加 ICACHE_FLASH_ATTR ,然后重新编译。
如果还不行,就要用更激进的做法,改ld脚本把所有的常数常量放到flash,读出时4字节对齐读出。然后关掉switch的jumptable,把一些中断中永远用不到的函数放在flash里。
pillarpeng
Postby pillarpeng » Wed Jan 04, 2017 11:00 am
vowstar wrote:上面的回答答非所问,不知道误导了多少人
感谢,解决问题。。。
lijay910
Postby lijay910 » Wed Oct 04, 2017 6:27 pm
您好,怎么解决的?
我在大部分函数前加了ICACHE_FLASH_ATTR,还是报section `.text' will not fit in region `iram1_0_seg'
YimingLi
Postby YimingLi » Thu Oct 05, 2017 10:40 pm
lijay910 wrote:您好,怎么解决的?
因为iram1_0_seg空间有限,只有0x8000=32KBytes,如果采用上述做法之后,依然提示这个错误,那么可以进一步,将所有或部分的const常数,通过在声明处加上“ICACHE_RODATA_ATTR STORE_ATTR” ,也放置到flash里不要驻留iram1_0,例如:const char abc[] ICACHE_RODATA_ATTR STORE_ATTR = "Welcom to Espressif";
ps: 常量也包括诸如 os_sprintf(my_str, "welcome to %s", company_name);里面的引号中间部分。所以,尽量少用这类函数,以免太多之后,增加对iram1_0_seg空间的显著占用;或者更换其他方式使用(例如机智云的参考代码中,定义了一个Gizwits_print函数,就很好的的解决了这个问题)。
希望可以帮到你。
lijay910
Postby lijay910 » Sat Oct 14, 2017 11:36 am
因为iram1_0_seg空间有限,只有0x8000=32KBytes,如果采用上述做法之后,依然提示这个错误,那么可以进一步,将所有或部分的const常数,通过在声明处加上“ICACHE_RODATA_ATTR STORE_ATTR” ,也放置到flash里不要驻留iram0_1,例如:const char abc[] ICACHE_RODATA_ATTR STORE_ATTR = "Welcom to Espressif";
希望可以帮到你。
您好,例如机智云的参考代码中,定义了一个Gizwits_print函数,关于这个能否提供具体的代码呢?我们没有它的这个参考代码,谢谢
lijay910
Postby lijay910 » Sat Oct 14, 2017 2:02 pm
您好,我在能加的地方都加了ICACHE_FLASH_ATTR 常量加了ICACHE_RODATA_ATTR STORE_ATTR
app目录下各目录编译后生成的.a文件总大小加起来303KB
ld里面分配情况是
iram1_0_seg : org = 0x40100000, len = 0x8000
irom0_0_seg : org = 0x40210000, len = 0x5C000
现在一直提示../../../../xtensa-lx106-elf/bin/ld: .output/eagle/debug/image/eagle.app.v6.out section `.text' will not fit in region `iram1_0_seg'
我该怎么弄了呢?谢谢
YimingLi
Postby YimingLi » Mon Oct 16, 2017 11:14 am
lijay910 wrote:您好,我在能加的地方都加了ICACHE_FLASH_ATTR 常量加了ICACHE_RODATA_ATTR STORE_ATTR
ld里面分配情况是
我该怎么弄了呢?谢谢
如果你已经对所有的常量进一步加了ICACHE_RODATA_ATTR STORE_ATTR的标志,依然“iram1_0_seg“错误,那就没办法了,只能说你的代码量太大了,相对于乐鑫这个版本的SDK留给你的开发的可用iram1_0_seg'太多了。基本上没办法了,删除一些功能吧。
如果你非要强行做下去,我可以给你提供一个思路,也可以实现。但是这个思路属于”馊主意”类型,需要你自己承担风险和责任。即使做成了,也需要你自己去分析和完整测试。当然,如果严格分析和严格测试后,发现没有问题,那么这两个主意也可能成为“好主意”:
(1)试一试换低版本的SDK,因为低版本的SDK对iram1_0_seg的占用比高版本的少,所以,越低版本的SDK留给用户的iram1_0_seg也会越多。
(2)修改ld文件,编译时强行将乐鑫提供的SDK库文件全部或部分放置到flash里,给你开发的固件程序腾出iram1_0_seg的空间。
但是这样做,是否会带来的问题,估计乐鑫不会保证。我也概不负责。:)
ps: 如果这个回复因可能容易造成误导而不适合出现在乐鑫论坛,那么乐鑫管理员可以删除。
YimingLi
Postby YimingLi » Mon Oct 16, 2017 11:23 am
ld里面分配情况是
我该怎么弄了呢?谢谢
或者,你可以使用下面的“假编译”的方法找出你还缺多少iram1_0_seg:将 len = 0x8000 逐步改大一点点,直到编译后不再出现这个错误为止,此时你改到的数值,和 0x8000比较的差值,就是你缺的部分。-- 但是这种修改,仅限于编译,即使编译成功后的代码也是不可以执行的,因为实际的iram1_0_seg最大就是0x8000。所以,这种方法我称之为“假编译”。
如果这个差值很少,那你就去尝试改你的固件代码,能精简的地方,就精简一下;能不要的,就给先删除;可重复性的代码,就做成一个函数,适当通过牺牲时间换空间;争取节约一些空间出来,说不定这样处理后,再改回0x8000就可以编译通过了。
但是,如果这个差值很大,那就参考我前一贴的回复,要么放弃或大删,要么自己去冒险。:p
YimingLi
Postby YimingLi » Mon Oct 16, 2017 11:29 am
希望可以帮到你。
在乐鑫论坛搜一下,有的。
