GPIO0 and GPIO2 flashing / gpio_init() mystery
blubb
Postby blubb » Sat Oct 14, 2017 8:46 pm
for a project I am using the very simple ESP-01 modules. I use the UART for communication with another uC. This is all fine.
Now I still have two free pins: GPIO0 and GPIO2. I want to use them to display the current WiFi status. I know these pins have to be high during boot, so I wired two LEDs so that they are driven in active low:
3V3 ---> resistor ---> LED0 ---> GPIO0
3V3 ---> resistor ---> LED2 ---> GPIO2
Well, the ESP still boots fine and I can indeed use gpio_output_set() to signal the stuff I want.
However, I noticed that on every boot both LEDs flash for a short period when they should not. I can even remove all the pin related code and the flashing still happens. Why is that? I thought those pins are inputs with pullups enabled as long as the bootloader is active and they basically stay like this until I change that.
Also, my second question concerns the function gpio_init(). There are many examples which call gpio_init() in user_init(void). But there is no further explanation. It is not mentioned in the SDK manual either. What exactly is this functions purpose?
Re: GPIO0 and GPIO2 flashing / gpio_init() mystery
Postby pratik » Tue Oct 17, 2017 11:20 pm
The gpio_init() is not required anyway, you can skip it.
And you are getting the flashes because GPIO0 outputs 40 MHz clock signal when the ESP8266 is booting. So you may have a dimly lit LED on boot.
The initial state of GPIO after booting can be set by the bootloader or "boot.bin". You can request a custom boot.bin from Espressif technical support. :)
blubb
Postby blubb » Wed Oct 18, 2017 12:43 am
Thanks for your answer.
Nice to know that gpio_init() is not required. I guess this is one of the things that get copied from example to example to example without questioning its use. That always makes me suspicious. ;)
The 40 MHz signal, does it happen before the bootloader? Then a custom boot.bin would not help. What about GPIO2? Why is it flashing? And what are the initial states of the pins with the default boot.bin? Not input?
