error with sdk 1.1.0
alexchang
Postby alexchang » Mon May 25, 2015 1:08 pm
seems something removed?
/user/user_main.c:241: undefined reference to `wdt_feed'
build/app_app.a(gpio16.o): In function `gpio16_input_get':
Makefile:247: recipe for target 'build/app.out' failed
/driver/gpio16.c:97: undefined reference to `PIN_PULLDWN_DIS'
driver/gpio16.c:98: undefined reference to `PIN_PULLDWN_EN'
/driver/gpio16.c:98: undefined reference to `PIN_PULLDWN_DIS'
build/app_app.a(gpio16.o): In function `set_gpio_mode':
/driver/gpio16.c:112: undefined reference to `PIN_PULLDWN_EN'
/driver/gpio16.c:115: undefined reference to `PIN_PULLDWN_DIS'
collect2.exe: error: ld returned 1 exit status
emt@starkais.com
Re: error with sdk 1.1.0
Postby emt@starkais.com » Mon May 25, 2015 1:26 pm
我也遇到通用的问题。
tve
Postby tve » Mon May 25, 2015 3:25 pm
Yup... They got changed from PULLDWN to PULLUP2 without explanation. I suspect that there isn't an pull-down the chip... In the pin description XLS file the modes are described as reserved. Go figure...
costaud
Postby costaud » Tue May 26, 2015 11:05 am
alexchang wrote:seems something removed?
Hi ,
Are you using the origional SDK?
It seems there is no PIN_PULLDWN-related register in GPIO16.h
Moreover, GPIO16 is totally different from the other GPIOs(GPIO0-GPIO15), please use the API to control GPIO16.
Note:
There are no pull-down functions on GPIO pad now, so we should never use these registers.
Add external resistance to pulldown the pin.
alexchang
Postby alexchang » Tue May 26, 2015 3:19 pm
Yes, I use original SDK 1.0, the gpio16.c is from some other sample project, I will try to remove gpio16.c first, thanks!
Postby ESP_Faye » Tue Jun 02, 2015 10:40 am
So sorry for the inconvenience,SDK_v1.1.0 release note updated http://bbs.espressif.com/viewtopic.php?f=5&t=481
ESP8266 GPIO don‘t support pull-down function,so related APIs are deleted.
Please add external resistance to pull-down the pin.
costaud
Postby costaud » Tue Jun 02, 2015 11:05 am
alexchang wrote:Yes, I use original SDK 1.0, the gpio16.c is from some other sample project, I will try to remove gpio16.c first, thanks!
Would you please send me the "gpio16.c" you are using , support-product@espressif.com
GPIO16 should never have been using these registers.
Users browsing this forum: No registered users and 19 guests
